Viewing 10 posts - 1 through 10 (of 10 total)
  • Hub and wheel experts (Hope)
  • trout
    I have Hope Fatsno Hubbed wheels and may want to get the rockshox bluto forks when available but it needs to be a 15 mm by 150mm Maxle
    Can I make some adapters that are 7.5 mm wider for each side or is it more complex than that
    hishairyness
    No, Hope are bringing out a hub for this fork so go that way, if you ad adaptors they won’t take the extra stress and risk damaging your fork and hub. I imagine it will void any warranty on both also. We’re stocking both forks and hubs shortly.
    coatesy
    Adaptors will also move your rotor away from the fork, probably too far for the caliper to align with.
    hishairyness
    and that….
    trout
    Cheers guys but just found this on MTBR
    Bluto + Hope Fatsno
    coatesy
    Looks like he’s had an offset brake mount machined up too (from the pics, didn’t look at the words).
    Andy
    Thanks Trout this answers my exact same question. Wasn’t aware of the White brothers adaptor 😀
    trout
    Me neither but my disk is 200 mm so might need to make a disk spacer for the hub instead.
    Will be spinning up the Lathe over the weekend
    rOcKeTdOg
    Did you make adaptors Troutie?
    dan11
    Old thread brought up, but hope make their own spacer to bring a 135mm/142mm front fatsno hub to 150mm to accommodate a bluto. This comes as a kit and includes a disc spacer too. Any hope dealer should be able to get you one.
    (I know they make it, as I have one)
The topic ‘Hub and wheel experts (Hope)’ is closed to new replies.
