Bear with me on this one.
Just gone back to a ht after years of various fs bikes. Quick spec is, early Ragley Mmmbop, Flows, Hans Dampf on the front, Nobby Nic on the rear, Fox Float 32s, Reverb and a Charge Scoop. Both tyres around 32 psi.
First proper ride out last night and I was getting what I can best describe as ‘bobbing’ under power from the rear end, it almost felt like it was bouncing at times it was that bad. I’ve never had anything feel the same even on the fs bikes. Rear end is a 10mm qr axle and is seated in dropouts properly, no cracks in the frame I can see and spoke tension seems fine both on the front and the rear.
Am I going mad or is there a logical/sensible explanation for this?
