Spagetti89 – it’s a bit soul destroying really isn’t.
I do wonder why a lot of people on STW in general (it’s not the first or last thread that will castigate the HR profession) seem to think that HR are evil personified. I work closely with both HR and the line (at the moment those are sales directors) in Global Fortune 500 companies and my experience of the line’s view of HR is certainly not in line with the consensus expressed here. That might be because people here typically aren’t working in Global Fortune 500 companies, or it might be that the people making the comments are also on their own ego, Nazi power trip.
I would agree that a lot of HR departments could do a much better job and should do a much better job, but that is, and has been, changing for quite a while now.
Brooes – to your original point. It’s reasonable to expect a moderate amount of confidentiality and to a large degree you ought to be able to trust HR to respect that. But the points made about them working for the company are correct so their first objective is to make sure the company doesn’t get sued.
Bear in mind, that by breaking confidentiality, without very good reason, it’s highly likely that the company would get sued. Good reasons would be things like you’re confessing to an act of gross misconduct or your disclosing such an act committed by someone else.
If you’re thinking of leaving you should under no circumstances tell this to anyone at the company. This constitutes a break down in trust between you and your employer and could make things very tricky for you.
