- This topic has 100 replies, 44 voices, and was last updated 13 years ago by williamtravis.
HOWWWWWW MUCH?????!!!!!!!!!!!!!
thehustlerFree Member
Find a good local craftsman and get a Howdens Kitchen, 18mm rigid carcase that will give the option of 'normal' or softclose doors and drawers or if you want the cheaper damper option they can do that too.
I have been out of the industry for a couple of years but still know quite a few very good fitters in the midlands area, and Howdens will send someone to see you for design purposes (free service)
Oh and btw somone above mentioned quartz worktops above being the bees knees, dont be so sure as quatz is porous which means it can absorb and hold germs/moisture, most worktops have some element of trade off and tbh you cant go too wrong with a good quality laminate (6 layers or more)
DezBFree MemberHaven't read all the thread, it grew too quickly!
Homebase did our kitchen and they did a very good job. No complaints at all. They sub-contract the work out anyway.
The soft-close hinges are just these things
http://i142.photobucket.com/albums/r90/dezb99/Junk/hinge.jpg%5B/img%5Dfor the price difference you quote, you must get the fancier, internally damped version. Worth £127 quid of anyone's money
molgripsFree MemberAnd don't get me started on garages and en-suite bathrooms!
We had a two bed flat once that had an en suite. And I mean a tiny two bed flat – not big enough for a family, so wtf are there two bathrooms?
Oh and Ikea kitchens are lovely 🙂
PeterPoddyFree Memberif you have the time, that would be great!
The main one is this – If you're cutting holes for hob & sink, put the worktop in place BEFORE you cut the holes. Worktop is very heavy, and if you do it elsewhere and then move it into place, it'll just snap where the thin bits are!
No need to screw it down, just rest it on the units, make sure it's clear underneath and then cut the holes before sliding gently into place.I think you can get the corners mitered by the factory these days though, which is handy.
Think about where you're going to cut as well. You might not get a pefectly straight end edge, but if there's a windowsill or wall at one end, make the cut there and leave the factory cut on the exposed end, then hide the other end easily.
As always, measure TWICE, cut once. 🙂
Tiling – Paint you wall first, tile, then put a strip of masking tape along the top of the tiles on the wall before you grout the edge. Gives a lovely crisp finish on the wall.
trail_ratFree Membermy fathers a builder – having spent a fair bit of my younger years working on building sites in summer – wouldnt buy a house that hasnt stood for 40 years. let along a new house :s Wouldnt let any of those "homebase/mfi/ikea/moben" folk install my kitchen or kettle for that matter …
much like my car – trusted local tradesmen only – reccomendations from mates or my dad. But the ammount of repair work my dads lot gets called in to do on the big guns newly fitted kitchens/bathrooms is rediculous !
including one where 20k worth of damage was done by a leaky pipe not connected correctly behind the units – wasnt spotted till the unit and laminate flooring started to bubble after about 6 months ! kitchen had to come out carefully , new floor boards and joists and replacement flooring , a chunk of the wall had to be replaced – old plaster and lathe wall soaked. kitchen units damaged all along the wall. – insurance covered it – the couple didnt want the cowboys the fitted it back in the house !
chickenmanFull MemberAs a joiner and kitchen fitter I'll add a few comments:
Kitchen fitting is not just a case of screwing boxes to walls; it is always obvious when removing a kitchen whether it was fitted by someone who had a clue and had the right tools for the job.
My experience of fitting B+Q stuff (is Homebase similar, don't know?) is that you wait months for the stuff to arrive and if there are any issues with what's supplied you're pretty much screwed. Worktops are crappy and only 3m in length (chipboard ones)
Ikea stuff Ok apart from service void issue,legs that fall off, the need to cut a tap hole in sinks (always tell customers to do that job themselves, or choose a sink from elsewhere!); same worktop issues as B+Q.
Customer service a bit better that the competition.
The best worktops are the ones that have ground stone in an acrylic matrix like Quartz, Minerelle or Corian. Really not a DIY job to fit it though.
Kitchen fitting should cost in the £600-£1000 mark depending on complexity of the layout, integrated apps, light trims etc. Expect to pay more for Acrylic matrix ones as fitter has investment in tools and training to fit this stuff.PeterPoddyFree MemberOh and btw somone above mentioned quartz worktops above being the bees knees, dont be so sure as quatz is porous which means it can absorb and hold germs/moisture, most worktops have some element of trade off and tbh you cant go too wrong with a good quality laminate (
Nope. That's granite that's pourous. I've already checked that out. Quartz isn't and is better. 🙂
DezBFree MemberThose pnuematic hinges are still only £3.24 😯
http://www.strutsdirect.co.uk/components/pneumatic_soft_close_cabinet_hinges.php?products_id=1581robdobFree MemberI think I gave you that tip, didn't I?
Anyway, Homebase soft close drawers are NOT the little plastic things you clip on, it's part of the drawer itself. Uses a magnetic damping drawer runner which does not break off in 5 seconds like the b and Q ones. I used to work for Homebase and I would still buy a kitchen from them as they are good quality and reasonably priced.
There has been days (ie one weekend I remember) where you got soft close drawers as a free upgrade.
I have looked round loads of kitchen suppliers and haven't found one that I'd go with apart from Homebase yet, although I would get my sink, taps and appliances elsewherebrakesFree Membercheers PP, some good advice there.
the big thing I'm worried about is where two perpendicular worktops meet and you have to cut a 45 deg angle on each – I can see this going seriously wrong.PeterPoddyFree MemberThey sub-contract the work out anyway.
They told us they didn't and had their own fitters, but that's by the by. If they subcontract, you're paying over the odds for the pleasure. I have no doubt they'd do a good job, but I can screw a unit to a wall just as well as the next man. So I will. I do realise we'll have to pay to have the worktop fitted but even the Hombase salesman admitted it would be easy to get that £1-2K less than they would charge.
I really do hope you're taking the pee Dez! 🙂
£1.69 each on Ebay.[/quote] And they're as near as dammit identical.
tiger_roachFree MemberI fitted out the kitchen in my old house with Ikea units – looked really good with stainless steel doors (steel wrap over wood); at the time they had these big alu tiles that made a great splash-back – so a metal looking kitchen on the cheap. I spent about a grand on everything and added a free standing stainless steel Smeg oven and a steel Baumatic hood. WIsh I'd got a photo as it did look pretty good when done.
robdobFree MemberThe best worktops are the ones that have ground stone in an acrylic matrix like Quartz, Minerelle or Corian. Really not a DIY job to fit it though.
+1. Very durable, look amazing. I would have one if I had the money.
The biggest problem customers ever had in my store was NOT listening. They were always told to check their order when it arrived to make sure all the boxes were there. 99% of the orders were fine and we never had a problem. Customers were advised that we could get any missing parts couriered to them within 24hrs if they told us in the first 10 days but after that it might take 2 weeks to get the bits. We had one a week where they hadn't checked it (but signed for it anyway) then kept it in the garage for 12 months, because they hadn't bothered booking a fitter. The worktops would warp in the damp and they'd damaged bits which they obviously blamed on us. Generally it was the fitter who got the stress as they were sent in to sort it out with the store. We did our best for them tbh but I did feel sorry for the workman.
I could frighten you with the markup on some of the items (only some mind you)!!
tiger_roachFree Memberthe big thing I'm worried about is where two perpendicular worktops meet and you have to cut a 45 deg angle on each – I can see this going seriously wrong.
Hmmm – I took the easy option and just put them up against each other and joined with coloured kitchen sealant – looked OK I reckon; certainly better than a less than perfect cut.
PeterPoddyFree MemberRob, for £127 I'll just shut the drawer gently FFS!!!
The hinges at £30-ish a door are a joke when I can get 5 doors worth for about £19 of the self same thing.
I'm not knocking the kitchens, and I've already said I was impressed by the service when we visited, but that's a smegging joke.
(Smeg-ing. Did you see what I did there? Eh?)
thehustlerFree Member45 degree joints on a corner are a bitch to do and are also a waste of worktop length butt and scribe every time
SuiFree MemberGet a Howdens Kitchen, if you can find somebody nice enough to get it trade, ££££ in savings. Got about 80% off the price on mine, mind I did help fit the fu(ker.
molgripsFree MemberRe granite, I dunno what the fuss is about them being porous. Ours are pretty dark in colour, greeny-dark grey, and we are just about the messiest people around. So we spill stuff and leave it for sometimes weeks.. and I've never seen a stain yet.
jp-t853Full MemberIf you can get a relative / friend with a Howdens trade account (Howdens are keen on selling kitchens)then there are some good bargains however it is wise to shop around for appliances.
We had a kitchen fitted to a very old house with very uneven walls and got a dedicated local kitchen fitter to do the install. Two 14 hour days for two men and it is perfectly scribed and fitted there is not a mm gap anywhere. The cost was £650 a couple of years ago.
Equivalent B&Q etc was almost three times the complete cost.
StoatsbrotherFree MemberAnother vote for Ikea units – (fitted 3 kitchens so far with them) – but you might run them a few cms off the wall on battens to get wires and plumbing behind if you need to and then splash out on a pro-fitted Corian or Granite worktop fitted by someone like Alaris with a decent upstand and a high quality (eg Franke) sink and taps.
DT78Free MemberTo save money when we re-fitted our kitchen we kept all the units and just replaced the worksurfaces / doors / handles / flooring & tiles.
Looks like a new kitchen without the serious price tag.
molgripsFree Memberits not about the stains its about the bacteria…….
So my worktops are unhygienic?
molgripsFree MemberBtw I was told that granite etc worktops needed reinforced cabinets. So you might not be able to retrofit worktops… No idea if that's true though.
JulianAFree MemberBeware buying ovens from Howdens – the inner glass in our Matsui one exploded after only ten months use, but as it had been installed six months earlier it was four months out of warranty and they have refused (so far) to supply another glass for free, despite the fact that there is evidence of this happening to others and it appears to be a poor design.
CougarFull Memberwe kept all the units and just replaced the worksurfaces / doors …
How do you go on with drawers? The fronts are integral to the drawer, what happens there?
simons_nicolai-ukFree MemberWe got units from these guys –
http://www.arena-kitchens.co.uk/It was a few years back so don't know if anything has changed but the stuff they sell is good quality and priced well below what you'd pay on the high street (Wentworth make the kitchens John Lewis sell as their own brand at a much higher price than Arena sell them for).
Very solid carcasses, delivered fully built.
Edric64Free Membermy kitchen cost 2 grand including taking a wall down and tiling the floor .Did most of the work myself and bought a second hand range cooker off ebay.At least buying a cheap one I wont mind changing it after a few years when I am sick of the sight of it
thehustlerFree MemberHmm matsui being an ownbrand of the DSG chain I would be surprised if it was supplied by howdens
JulianAFree Memberthe hustler – Member
Hmm matsui being an ownbrand of the DSG chain I would be surprised if it was supplied by howdensWell it certainly came from Howdens… Thought it was a Matsui – maybe not. Anyway, an oven from Howdens caused us problems. It's an hja 3300 model, anyway.
brakesFree Memberbutt and scribe every time
which uses routers and jigs/ templates I guess? can I hire templates?
anyone got a link to a decent explanation of how to do this?thehustlerFree MemberHewdens used to hire the jigs out, bit long winded the explanation of how to do it, but think there are youtube links if you google it
DT78Free MemberHow do you go on with drawers? The fronts are integral to the drawer, what happens there?
We only had one carcass which is for drawers (so not cupboard with drawer above style) so was quite easy to replace the 4 drawers in it.
Biggest pita was getting the doors right on the integrated appliances. Fridge door isn't quite lined up right, but only I can spot it
fwb2006Free Membersimons_nicolai-uk That arena kitchens is the place we are looking at ordering from, they are now called Alaris, good to hear you had a good service from them. Infact we got our bathroom from them and they fitted it a few weeks ago.
Blazin-saddlesFree Memberbutt and scribe every time
anyone got a link to a decent explanation of how to do this?I fit kitchens for a living and although it sounds like I'm drumming for work (which I'm not as I'm booked until November) I'd leave this to pro's unless you want it to look crap. there are a few tricks to doing a mason mitre properly, not to mention quite a few expensive tools. I charge £50 per joint on work tops + a flat fee for sink/hob holes and finishing work if I've not fitted the kitchen. you'll soon spend more than that if you cut a worktop wrong and have to buy another. Also, not having a go but DON'T follow PP's advice on worktop fitting, very much the wrong way to go about things, oh, and never cut a 45deg mitre to join 2 90deg worktops, they always fail eventually and look rubbish from the off.
BTW the expensive soft close bits PP is ranting about are about £5 for a blum hinge and damper but the soft close Blum drawers cost around £50ea to buy.
fwb2006Free MemberBlazin, how do you rate the Pronorm kitchens? Or could you give me the name of some good quality ideally german makes that won't totally cripple my ever dwindling bank balance (~12-15k)> Thanks.
falk1Free MemberRight I'm being a bit lazy here, but there's loads of online shops out there you could have a look at. I've never been too happy with Homebase so wouldn't go there either, but I'd def have someone skilled to put it together. http://www.magnet.co.uk http://www.kitchensdirect.co.uk
http://www.fashion4home.co.uk http://www.cutpricekitchens.co.uk You could always shop around,get cabinets from one place and then the handles etc from another. Might work out cheaper.TandemJeremyFree Memberanother vote for Ikea here.
As for concrete kitchens someone suggested further up – a acquaintance of mine doe this already – casts concrete worktops in situ
The topic ‘HOWWWWWW MUCH?????!!!!!!!!!!!!!’ is closed to new replies.
