Mavic explain how their rim wear indicators work on here;
http://www.tech-mavic.com/tech-mavic/technical_manual/data/docs/products/2_119.pdf
INTERNAL:
Process:
The inside of the braking surface of the rim is machined on both of the wings of the rim.
Principle:
When there is too much wear on the rim, a little hole appears on each of the 2 braking surfaces of the rim. Depending on the ad
justment of the brake pads, it is possible
for the wear indicator to appear on only one of the 2 braking surfaces. In any case,
the appearance of the wear indicator on at least one of the 2 braking surfaces
means that the sidewalls are too thin, and it could be dangerous to continue to use the rim. It should be replaced as soon as p
ossible.
The position of the wear indicator is marked by 2 yellow arrows on the stickers on the rim, opposite the valve hole.
Refer to the chart on the previous page to find out which rims offer this internal wear indicator.
INTEGRATED IN THE PROFILE:
Process:
the wear indicator is an integral part of the rim. There is a groove on the entire circumference of the rim, at the center of t
he braking surfac
Principe :
The groove becomes more shallow as the braking wears down the surface of the rim.
Its disappearance, on one side of the rim or the other, means that
the thickness of the braking surface is too thin and it could be dangerous to continue to use the rim. It should be replaced as
soon
