You can see the difference in the crown height; black ones are 05 and white ones are 06; probably 15-20mm lower crown.
But, just had a look on google and maybe you can do it…….
Take your top caps off and there should be a spacer (shown in red below); this needs to go underneath the cartridge (shown in black below) under the rebound spring.
If the spacer isn’t ontop of the spring when you remove the top cap, it could be below the spring so you’ll need to tip the forks to get it out (do it over a jug to catch the oil). I’ve had this before (on 05 forks). I also appreciate the image is for MY2005 forks, but it was linked on a forum stating it can be done with 06 forks. Worth a go I would say.
Posted 7 years ago
Viewing 8 posts - 1 through 8 (of 8 total)
The topic ‘How to reduce travel on Marzocchi 66 rc2x?’ is closed to new replies.
