Viewing 5 posts - 1 through 5 (of 5 total)
  • How to knock the bearings out of my front hub?
  • bomberman
    I’ve got some replacement bearings and I’ve taken the end caps off but there’s a metal tube inside between the bearings which is stopping me from getting any purchase with the drift. Any ideas on how to get them out?
    It’s a front hub, cartridge bearings obvs.
    matt_outandabout
    Which brand hub?
    I just had to work out on a WTB hub – the inner ‘tube’ could actually be pushed to one side with a firm push on a long lever – that then gave me enough purchase on the one bearing to batter the thing out. As soon as it moved a mm, I could then move the tube easily and use a drift.
    devash
    This’ll do the trick. A thin plastic tyre leaver usually does the job.
    Del
    Or it’ll have a lip on the inside, so just **** it and it’ll take the bearing out with it.
    bomberman
    job done, thanks!
The topic ‘How to knock the bearings out of my front hub?’ is closed to new replies.
