My daughters car has a pop up sunroof which has leaked for a while, I just cant get to the bottom of it though.
So far I’ve tried:
Vaseline on the seal – no luck
Remove seal, clean and replace – no luck
Bed seal in mastic – no luck
Replace seal – no luck
Fit a second seal round the outside of the first (ie double seal) – no luck
Finally a bought some expensive waterproof duct tape and taped the glass/frame joint completely – still bloody leaks!
This morning there was about a litre of clear water sat on the bin liner she wisely keeps on her seat. Its dripping in from the ceiling lining where there’s a dip behind the sun visor, and can be either driver of passenger side depending if the cars on a side slope at all.
[url=https://flic.kr/p/BQXBr7]2016-01-03_08-13-12[/url] by Allan, on Flickr
[url=https://flic.kr/p/Cmm7uW]2016-01-03_08-13-30[/url] by Allan, on Flickr
[url=https://flic.kr/p/CmmamY]2016-01-03_08-13-56[/url] by Allan, on Flickr
Any other suggestions? This is driving me (and her) nuts!
Tape up the outer edge as well. Spray a hose pipe over it. If it doesn’t leak take off the tape over the glass. If it leaks you’ve narrowed it down a bit.
And what he said^^
As above, check the drains aren’t blocked. Normally two on the front that drain to door openings or wheel arches, and two on the back that run to the hatch. Look for little rubber non-returns that might have got gunked up.
There was a bit on a leaky sunroof on an episode of Wheeler Dealers a while back. If I recall correctly it was leaking from the hinge side (so the front edge) and the front edge of the glass panel had lifted a bit. His fix was to bend the metal leaves of the glass part of the panel, that formed part of the hinge mechanism, up a bit to pull the front edge of the glass down so it pressed against the seal more firmly.
In another episode he had a leaky side window on some frameless doors (the BB7 episode I think) and he used short sections of rubber hosing to pack out the rubber door seal so it pressed more firmly against the glass window.
Might not be exactly the symptoms or causes in your case, but might give you some ideas how to address.
Ah yeah first thing I did was check the drains. Forgot that! They were fine.
Bikemike – it is a Clio! I’ll have a look at that thanks but I’m sure its lower than the sunroof and at the back so I’m surprised water would run right to the front. It’s parked on dead flat generally.
The Clio sunroofs are notorious for leaking
You need to take the sunroof out altogether, take the glass out , remove the trim and undo the 10 mm nuts that hold the frame in, then reseal
I did my sons Clio and this cured it
Cheers easygirl. I didn’t realise there was another seal under the frame. I’ll tape it to see if that stops water getting in then follow the vid if we ever get a dry day
As already mentioned especially with old Clios, it’s nearly always the drain holes, welding wire sorts it until it blocks again!!
Even worse when it happens to an old Laguna with electric everything and water gets into the expensive BSI unit (box full of relays) and causes mayhem 😯
Posted 8 years ago
Viewing 13 posts - 1 through 13 (of 13 total)
The topic ‘How to fix a leaky sunroof?’ is closed to new replies.
