No problem – I'll continue!
If the chain has stretched running on the rings, the chain and cassette will have worn, but it's only a problem when the chain has worn beyond 1% and the gap between contact points on the rings becomes too large for a no-worn chain to run.
Say if you run a chain to 2% stretch on the rings (which will also have worn to match), them put a new chain on at 0.5% stretch – the distance between pins on the new chain will be shorter than the worn contact points on the old rings, so it won't run properly. By replacing the chain more frequently you maximise the life of the rings & cassette – you can easily get multiple chains worn out before the cassette and rings need replacing. I'd aim for three per cassette, although if you tend to use certain rings more than others (i.e. granny ring) you may find they need replacing sooner.
If that not clear, don't think about it and aim to replace cassette and rings after 3 worn chains. Feel free to ask if I can be of more help, but don't waste your hard earned until closer to 1% 🙂
