- This topic has 121 replies, 59 voices, and was last updated 7 years ago by paton.
How real is steel?
cynic-alFree Member
kayak23 – Member
ovalised chainstay which really does add in some compliance.
BS Bingo!
6079smithwFree MemberI find my steel frame to be laterally stiff but vertically compliant
kayak23Full Membercynic-al – Member
kayak23 – Member
ovalised chainstay which really does add in some compliance.BS Bingo!
As I said though, having ridden this bike, it feels comfier than any other hardtail I’ve ridden, BS or otherwise.
Anyway, meh….NorthwindFull MemberToasty – Member
My mk1 Scandal was lovely, I bought a mk2 one,
That was my Matrix moment- I had a mk1 scandal and rode a mate’s inbred, and frankly if you blindfold tested them there’s no chance at all you’d get it the right way round. Woah!
But my Soul was every bit the stereotype.
pictonroadFull MemberAs it’s a steel love in I’ll go against the grain and say I wouldn’t buy another steel MTB. I’ve had steel hardtails (Dialled and charge) and a few aluminium (GT and Cannondale).
I understand if you’re a particularly hard rider and want the security, for me, it was weight I didn’t need and I got on better with the aluminium bikes.
Carbon is my favourite material to date but I did really enjoy a skinny lightweight steel SS in town until it got half inched.
(I suspect it’s more down to angles and components though)
ampthillFull MemberI’m no metal expert so can you explain why?
Heat treating makes the steel harder, then it’s tempered to make it less brittle I thought.
If they don’t harden and temper it, what would that mean for a length of tube in this circumstance?The stiffness of steel (Young’s modulus) is not a variable that is being changed here. All steel has he same stiffness scaffold poles through to 853
I think seat post is what most of us can “feel” sat down
Some one linked an article here once saying that in blind testing the stiffest road frame vs the least stiff equated to a tyre pressure difference of 4 psi. But the slightest hint that a frame was a bit faster and suddenly people started being able to describe extra stiffness, even if they were on the bendier frame
Just think about a MTB hitting a rock with the back wheel. The think about the ratio of the deflection of the frame to the deflection of the tyre…
DelFull Memberhad a 456 ( trigger’s mum’s bathroom blue’ one ) that felt heavy, dead.
a regular inbred which was fine.
an 853 inbred that rode identically to the regular gaspipe one as far as i could tell, at least until i ripped the headtube off it.
a P7 – post CEN, heavy, deadish.
a genesis alpitude, 853 and quite light, but a smaller frame than i should have been on, really.
i now ride a 2013 chameleon. by all accounts i should walk like john wayne these days. it’s a nice, light bike, and runs a 2.4 chunky monkey in the back tubeless. dead comfy. 8)
steel is good for low volume manufacture, which is the main reason it still gets pushed, IMO.
how much movement do you realistically expect to get out the back end of a frame? 2mm? 3mm? any more than that and every time you push the crank the wheel is going to be rubbing the other side. 😆
compare that to a 2.4 tyre at 25psi.chiefgrooveguruFull MemberEssentially though, lateral stiffness will vary due to tube size, vertically all frames that don’t have a spring there will be “stiff”, due to triangulation (this will also eliminate any benefit from the ovalisation on the chainstay – if you can’t compress the seatstays it doesn’t matter what you do to the chainstays). I’ll include a calc for tyre stiffness too (assuming a flat surface to give the best possible effect of frame vs tyre). I suspect that any difference vertically will be marginal comparing typical steel vs typical alu. frames.
The seatstays won’t compress but they will bend outwards under a compressive load, so shaping the chainstays can have a benefit.
I think you can perceive very subtle differences in frame behaviour. I mean, you wouldn’t consider 0.5 degree a big change in an angle but it’s pretty obvious to me when riding, be that seat or head angle. Likewise you wouldn’t consider 5mm a big dimensional change but I’d notice that in reach or BB height, is obvious.
It’s all very well saying that big low-ish pressure tyres make more difference but cars have big low-ish pressure tyres too, and suspension, and the chassis stiffness still matters.
patonFree MemberStiffness of Reynolds tubes, on page 4
http://www.reynoldstechnology.biz/wp-content/uploads/2015/08/rtl_steel_alloys_extract.pdf
NorthwindFull Memberampthill – Member
Not when we’re using the same seatposts (which is become the case more and more with droppers).
But try it stood up… I had a Ragley Mmmbop (alu, stiff as ****) and a Ragley Ti (durr, ti, still fairly stiff for a Ti frame but way less stiff than the Bop), and with the exact same parts, the difference in ride was huge. It wasn’t comfort, it was grip- the Bop bounced off everything, the Ti didn’t.
How many mm of deflection was this? Neither know nor care frankly. It’s obvious that small differences can be very telling though. 1mm more grip can be the difference between comfort and agony, and invisible differences between 2 bars can be the difference between fatigue and not.
cynic-alFree Memberchiefgrooveguru – Member
I KNOW you think you can 🙂
Seriously, even if all other relevant variables are the same, how about changes in weather, trail, you between various rides?
Northwind – same tyres and pressures?
philjuniorFree MemberThe seatstays won’t compress but they will bend outwards under a compressive load, so shaping the chainstays can have a benefit.
True, which is why I’ll assume the extreme case of a dekerf style all the way up and then 90° to bring the stays together. Might see if I can stretch to a GT triple triangle too.
NorthwindFull Membercynic-al – Member
Yup. Same wheels, same bars, same forks. And I had both frames for long enough to know them inside and out
TBH, most people never get the opportunity to make this sort of real world comparison. And no wonder, it’s not that common that you can get the “same frame, different materials” thing. So there’s lots of perfectly reasonable sounding common sense theories out there that rarely get tested. If you rode my BFe and Soul you’d feel a difference too, but it was less clearcut. If you didn’t feel a difference switching to my wibbly wobbly Soda I’d be amazed. Or my old Scandal and an Inbred.
But like I say, nobody doubts that a mm of grip thickness can make a huge difference. Presumably because practically everyone who’s interested in this sort of thing has tried it.
ampthillFull MemberIt’s all very well saying that big low-ish pressure tyres make more difference but cars have big low-ish pressure tyres too, and suspension, and the chassis stiffness still matters.
OK I should clarify what I meant
Frames band quite alot in response to forces outside the plane of the frame. A quick press on the pedal of a stationary bike shows a deflection of that nature. In my riding expereince deflections of this type aren’t a good thing as they can do weird things to the steering. This the “stiff but vertically compliant” phrase starts to raise eye brows
Oh and no one says car is comfy as the chasis is flexible? Or do they? I may move in the wrong circles
ampthillFull MemberBut try it stood up… I had a Ragley Mmmbop (alu, stiff as ****) and a Ragley Ti (durr, ti, still fairly stiff for a Ti frame but way less stiff than the Bop), and with the exact same parts, the difference in ride was huge. It wasn’t comfort, it was grip- the Bop bounced off everything, the Ti didn’t.
To be sure about this then it would need a double blind study?
MoreCashThanDashFull MemberI like the way steel bikes look. Was all set to buy an expensive carbon road bike and just fell in lust with a steel one at the last minute. Might not be the best material/bike, but it’s the one I want to own and ride.
kayak23Full MemberI think with steel you’re not talking about compliance in terms of ‘travel’, of course not, it’s feel. It’s just different. Different materials feel different. Combine that with different design elements and you get further differing characteristics between different frames.
Nobody is suggesting a steel hardtail is like having 100mm of suspension.Pick up an alu bar and whack the side of a house with it. Then do the same with an iron bar, and then again with a wooden bar.
They’ll all feel slightly different.
That…NorthwindFull Memberampthill – Member
Nope. If you want to make a scientific study out of it, then sure. But observation is perfectly valid. Especially when the outcomes run counter to expectations, like with the classic Scandal/Inbred comparison.
It’d be really interesting to do a double blind of course.
patonFree MemberMalvern RiderFree MemberI not be the best material/bike, but it’s the one I want to own and ride.
Yep. I now have only steel bikes. Easton Taper-wall frames (Rocky Mountain and Kinesis) have been nice to ride in the past, but not so strong and easily dented. Also done the Cannondale thing, enjoyed light and super-stiff but I always missed skinny steel. Zingy and feels real. Another factor is I’m getting old and somehow seem to love my steel bikes like old friends.
justinbieberFull MemberThis thread has been great, and I guess I’ll find out how real steel is for myself in the next few weeks. Stanton Switchback on its way to me soon…
mikewsmithFree MemberSteel it’s just a passing fashion fad, sooner or later they will be all back to Alu or carbon 😉
kayak23Full MemberThere’s always a few Jones bikes fans around here. He has quite a lot on his site about steel and how different types exhibit different riding properties.
How would they be in alu? Would the material make any difference?stevemuzzyFree MemberMy comparison. 2 steel bikes. Both similar style, agro hardtail.
Current pp shan
Previous on on 456 summer season
Despite the tubes being much smaller on the 456 and a 27mm seat tube the shan is significantly comfier. The pig iron 456 used to rattle down everything with lots of loss of traction. The shan? Far far less. Despite me getting older the shan is faster as well.
jamj1974Full MemberI think when people talk about compliance they are also describing about a materials ability to absorb vibration…
Different materials with different wall thicknesses and shapes do seem to dampen the transmission of vibration.
jamesoFull MemberThere’s always a few Jones bikes fans around here. He has quite a lot on his site about steel and how different types exhibit different riding properties.
That bike flexes vertically because of the design mostly but the steel bike is said to be less vertically springy than the Ti. Ti has a lower stiffness value.
I was reading this thinking I’ve seen that Production Prive stay shape before – my Jones steel diamond frame uses it, he’s been doing them in almost that same shape for ages. That bike / rear end has pretty much zero give vertically imo and the SS has a bend in it that the PP hasn’t. Not much spring/twist up front either, no doubt it’s a stiffer frame overall than most other steel MTBs I’ve ridden. Rides really well and it’s very comfy, the post flexes and the ride position is good.
So is Jones steel less real than a more flexy frame.. dunno. It’s a bombproof bike that rides really well, isn’t that heavy and I like the fact it’s made of steel.
The amount flex that design encourages isn’t generally a good thing for a welded aluminium frame but I expect it could be done. It’s only a bit of give, not 2-3″ of travel. Could be a great bike I think if it was comfy and about the weight of the ti version but cheaper. Or not cheaper, after all the alu tubes had been custom-made for that design and all the R+D done to make it reasonably durable.
jamesoFull MemberAnother factor is I’m getting old and somehow seem to love my steel bikes like old friends.
I think there’s a lot to this. Subjective and a non-engineering take on it but for some of us it’s a factor. Durability is important – if I like a bike and I’m not changing shocks or a lot of parts very often then a 10-15 year lifespan may be realistic and that adds a lot of value. You can get the same lifespan in other materials but steel seems to manage it most consistently. It’s old tech, it’s tough and simple, it’s less ‘now’. Outside of fashion never really goes out of fashion, or something like that.
steviousFull MemberSteel is real but carbon is lardons.
Nothing rhymes with aluminium though 🙁
tall_martinFull MemberThe magazine tested this year’s ago. They had a black and white charge hardtail in. Anyone who rose one had to ride the other and describe the differences. One was lighter by an amount you would notice in a magazine test but that wasn’t commented on much. Other than that people didn’t describe much difference.
One was steel and one was ti.
Not double blind, but blind and made a mixed point.
I think the conclusion was if you want ti buy it 🙂
jamesoFull MemberThe magazine tested this year’s ago. They had a black and white charge hardtail in. Anyone who rose one had to ride the other and describe the differences. One was lighter by an amount you would notice in a magazine test but that wasn’t commented on much. Other than that people didn’t describe much difference.
I think the conclusion was if you want ti buy it That test was a good mag feature but imo only showed that Charge made both frames to a similar stiffness and many people can’t spot a 31.8mm tube compared to a 34.9mm tube : )
Valid conclusion either way : )cookeaaFull MemberI’m honestly less bothered by frame materials than ever, there’s so many other factors affecting the frame’s function and the intangible “feel” factor that Steel is just as ‘Real’ as any other material it’s more how you use it…
If anything now I’m a fan of Composites which has come a long way on bikes in a relatively short time and more is being learnt about all the time most, if not all, of the benefits that people claim for steel can be claimed for Composites also…
Notions of “Character” and sentimental attachment to older steel frames are fine, but TBH the HT’s I want to ride now are more “Modern” geometry; the longer/lower/slacker thing suits me and contributes more to comfort than the inherent extra give from a slightly noodly bit of steel tubing…
That said I’m hanging on to my old 456-SS for a good long while yet.
As for Ovalised seat stays? Poor Kayak He’s not actually wrong you know, it’s simply that nobody (Including the manufacturers) have really bothered to quantify the effect of that minor tweak.
All PP have done is squashed a bit of tube in a vice to change it’s section properties, it’s a simple, but rather effective bit of engineering.
What that will have done is make it bend/flex more readily in the vertical plain with less input load, of course you still have the same cross section of material for compressive/tensile loads so ultimate strength for the structure hasn’t been affected too much, it’s using the material, manipulating the form to make the most of it’s elastic properties…
Has anyone ever tried to work up a set of load cases for a HT frame?
I know I haven’t but I bet it’s nothing like as straight forwards as some would like to imagine.matt_outandaboutFull MemberRear tyre, seatpost size/type/extension and saddle have far more influence on the comfort/springyness of these things.
I also thing frame design can allow for flex movement, but it is a couple of mm compared to a couple of cm from a tyre…
That said, I have ridden a few Alu frames that ‘buzzed’ my feet in SPD’s unless you were running daft soggy rear tyre.
My Sanderson is also a seriously spriongy – you can make it flex and feel the flex as it chatters over stuff.
I am intrigued to try a more modern alu HT – there is something very clever about the Pinnacle alu HT’s running 27.2 posts – and some of the more compliant frames (Sonder Transmitter for example). I think the weight saving would be fabulous.
mindmap3Free MemberI like steel frames, but it took me a while to get it – I had BFe and that was pretty dead and heavy to ride. It was almost as harsh as the Tazer that it replaced. I then swapped it for a Slackline 853 which is when I started to get the steel thing – that was a lovely little bike to ride. The 631 version that replaced it is supposed to lose some of the magic because of the bigger seat and head tubes.
Since then I’ve had a steel Switchback which wasn’t too bad; it was a bit stiffer but not horrendous. I do wonder if the second generation will be stiffer again due to the yoke and internal routing that means thicker tubing. This has affected the Ti version – I had a Mk I Ti that was stolen which was replaced by a Mk II and it’s lost a bit of the Ti feel that made the Mk I such a great bike to ride.
Of the current Steel Stanton range, the second gen Slackline frame is lovely to ride. I borrowed one and loved it. Really loved it. A friend has gone from a Ti Switchback to a steel Sherpa and loves the 853 tubeset as well. The new Slackline seemed to capture a lot of what I loved about the one that I had. Trouble is a lot of people don’t get it and see it as not as good as the Switchback. As a general trail bike, the Slackline wins hands down for me.
jamesoFull MemberAs for Ovalised seat stays? Poor Kayak He’s not actually wrong you know, it’s simply that nobody (Including the manufacturers) have really bothered to quantify the effect of that minor tweak.
He’s not in tube properties sense but I think it’s marketing stuff that makes riders attribute much comfort to that sort of stay design, in most cases. I’ve done basic FEA for the main frame deflection when you go from round to ovalised tubes, it’s not much in actual mm of flex but it’s significant in % terms. It becomes ‘noticeable’ (subjectivity warning) if you’ve got 2 otherwise similar/same frames to ride and both TT and DT are ovalised on one of them – I did some trials of old FW Evans ‘Evans Oval’ (a 1920s patent) frame tube specs built into a more current road frame geometry.
For the rear end it’s not a loading I’ve set up so I haven’t quantified it, from riding a load of bikes with different tubed but similar-sized rear triangles I’d put it in the reams of micro-tuning and princesses and very small peas. I’d suggest the Jones and PP rear stay ovalisation adds sideways stiffness but makes little (or less..) difference to vertical give since vertically it’s a triangle, a small one at that on the PP. I can’t feel flex there in the vertical plane of a standard bike frame design and I think I’m sensitive to or able to isolate aspects of frame feel fairly well.
I’ve also seen trad diamond shape frames heavily loaded from the seatpost on ISO test jigs and the stays are a small part of the overall flex of the frame (design / tube bends or junction alignment make more difference). The thread that was linked to earlier in this one had a good discussion on all this.djgloverFree MemberI’ve had 3 steel bikes and I sold them all, the weight of the frame outweighed any ‘zing’ or compliance. I’ve owned several carbon and aluminium bikes too, and currently have 2 carbon and 2 aluminium bikes. Even reasonably high end steel was either too flexy, 853 lemond zurich, or too heavy and dead feeling, condor fratello. I have a 10 year old Carbon Look frame that provides all the zing I expected to find in steel frames.
kayak23Full MemberAs for Ovalised seat stays? Poor Kayak He’s not actually wrong you know
Sweet, I was beginning to think that I’d imagined it all and it was all just marketing BS Bingo… 😉
kayak23Full MemberIn terms of marketing BS while we’re there, maybe I see some of the bike industry through rose-tinted specs but,a lot of these smaller companies, Production-Privee, Transition, Cotic, Stanton etc are by and large started and run by riders.
Now I know that products have to sell and that a lot of what helps them sell is a bit of harmless marketing BS, but somewhere, somewhere deep inside I’d like to think that they ride bikes…a lot, and so wouldn’t generally just chuck a load of shaped tubes together and make up a load of twaddle about them to sell to unsuspecting fools such as I…I take a lot with a pinch of salt, but at the same time, a lot of these companies are run by some talented riders and I sorta think that they may have a bit more integrity than the massive corporate outfits…
More fool me…bucksterFree MemberI understand that modern tyre size, fork travel etc are having a huge impact on handling and feel. But, all bikes have same/similar so, the frame will impact the ‘remaining’ handling feel.
I had a Kona Lavadome in the earlyish 90’s, with rigid forks, 1.9 and 2.1 tyres, the steel feel was very, very real compared to my mates alu Cannondale which was far stiffer.
These days, there must be some dilution to the steel is real mantra, purely because of the huge changes mainly in wheels, tyres, forks.
That said, I still love steel
I dont think it fair to include road steel frames when comparing steel is real in an MTB sense. I have raced steel road bikes, Alu road bikes and steel track bikes, as a road frame material I still rate it for clubmen style racing (i.e. up to Cat2 as was). But, there is nothing wrong with any other frame material IF the geometry is accurate for racing.
My guess is this will rage for decades. Fact is, I think more of the steel frame builders build frames with ‘pushy’ geometries as it allows a differentiation in a busy market and, allows them to build some real fun bikes, the big builders need to sell mass market products to keep the corporate rev counter going, carbon fits that bill.
philjuniorFree MemberI think the marketing bs that annoys me (and applies to all HT frames/rigid frames) is the “vertically compliant but laterally stiff”. I can see that something like the jones up there will allow some (possibly discernable – in fact probably discernable with the frame above and the effective seat tube length) vertical flex at the saddle, but they’ll still be flexy laterally (pretty much regardless of material, although with increased stiffness from fatter tubes).
Then people start talking about things feeling zingy, I think that basically comes from a lightweight build with a bit of lateral flex in the frame. And that’s fine, if that’s how you want your bike to ride – I don’t get too hung up on stiffness, as long as it vaguely goes where I point it and doesn’t get a speed wobble on.
As for durability, well like everything else design and fabrication are far more important than the material. There are fatigue tests – I think for a German mag – that will back this up – and the CEN tests are just a fatigue test too, after all. If steel frames were failing it, what does that say for their durability?
The topic ‘How real is steel?’ is closed to new replies.
