Viewing 17 posts - 1 through 17 (of 17 total)
  • How much weight do you save going from 3×10 to 1×11?
  • Goldigger
    I weighed the bits as I took them off my bike.
    XT 11-36 10 speed cassette 337g
    XT triple crankset 24/32/42 776g
    XT chain 268g
    XT rear derailleur 261g
    XT front derailleur 137g
    XT front shifter/cable 146g
    XT M8000 Cassette 11-42 433g
    XT M8000 32T crank 689g
    XT M8000 chain 263g
    XT M8000 rear derailleur 272g
    XT M8000 rear shifter 131g
    Weight saving 137g
    That’s £2.08 a gram 😀
    dryroasted
    just go 1×10
    Scienceofficer
    Which Is why Is only do it if I was replacing written out stuff anyway.
    trail_rat
    You’d save more if you were fitted and didn’t need a dinner plate at the back 😉 1×1 even lighter still.
    schmiken
    What did the old rear shifter weigh?
    nickjb
    Weight wasn’t really a significant reason for the switch for me.
    Goldigger
    Oh yeah forgot old shifter
    126g
    So add another 5g
    Now that makes it worth while 😀
    tallie
    I make that a 263g saving which assuming your original figure was correct equals roughly a £ a gram which is the old weight weenie truism?
    swanny853
    You could have put a new ring on the old cranks which would bring the lb/£ down a fair bit!
    nickjb
    Or just binned the front mech which gives £0/g. Pretty good. In fact if you sell the old mech you are being paid to save weight.
    edhornby
    Reuse the old cranks? No weight difference in the arms, just the fewer rings
    sam_underhill
    Those XT cassettes are seriously weighty!
    Isn’t an x01 about 270g? Granted, it’s more expensive, but it will be interesting as to how it effects the £/lb ratio.
    mikewsmith
    You bought the very heavy less range cassette….
    wallop
    I didn’t do it to save weight – I did it to fit my reverb remote on my bars more comfortably.
    antigee
    waits for coaster brakes to come (back) into fashion – then maybe 0.5 handlebars will be all the rage leaving a spare hand to push less awesome riders out of the way…”passing”
    cookeaa
    Sunrace 10 speed? ~£50 l 395g apparently.
    Superstar oval ring £26 / 50g
    Bin front mech/shifter/rings…
    For £75 you can save about the same weight (as if it really matters) and decide if a 1xN – 11-42 drivetrain is really for you without spankings ~£300 on M8000…
    deadkenny
    Biggest weight loss may be in burning fat due to the extra fitness you’ll need for 1x over 3x 😀
    (unless it transforms to muscle)
The topic ‘How much weight do you save going from 3×10 to 1×11?’ is closed to new replies.
