Viewing 40 posts - 1 through 40 (of 168 total)
  • How much weight can I lose in 3 weeks?
  • molgrips
    After going back up to almost pre iDave weight, after next weekend I will have three weeks til my holiday. What do you reckon I will be able to lose in three weeks?
    Jamie
    *pulls up chair*
    BoardinBob
    Actual loss of body fat, about 6 pounds sensibly if you’re very diligent
    Much more possible through dehydration but that’s not sensible
    bigad40
    3kgs
    jota180
    Are you going as hold luggage or something and paying by the kg?
    IanMunro
    *pulls up chair*
    *pulls up chainsaw*
    How much does a leg weigh?
    samjgeorge86
    6-8 lbs.
    RoganJosh
    Stone a week by eating green salmon
    bigblackshed
    15kg in 2 weeks.
    I did have dysentery*** and was knocking on the gates at one point.
    ***Not a sensible diet plan.
    molgrips
    No we are going to America where I can get jeans I like for really cheap. I just don’t want to have to buy fat sizes 🙂
    mikewsmith
    3-4kg last week due to a milder version of what bigblackshed had. I had an intolerance to food…
    cpsilver
    Gastroenteritis for the last week has helped me shift some weight, not recommended.
    poah
    either catch a disease or stop eating
    wanmankylung
    So that’ll be the iDave diet added to the list of fad diets that dont work. Meanwhile my exercise loads and eat a sensible normal diet has seen me got from 15 stone to 11 stone and keep it off. Surprising that.
    Pigface
    How many limbs can you afford to lose?
    What jeans?
    Jamie
    You seem kinda awesome.
    ampthill
    For jeans?
    Any way multichoice answer:
    A You are propellerly committed to long term change and you can start loosing weight at a sensible rate now. Buy the jeans in a suitable size and they should fit s in a month or so
    B Start starving yourself now. Arrive America and squeeze into jeans on first day and buy loads. Generally trough out in America as the portions are huge, your on holiday and your body has just left a famine. Return from holiday and place jeans in draw and never have to worry about them wearing out…
    maccruiskeen
    It worked within the parameters that iDave presented it, which was rapid weight loss as a short term aim – such as in preparation for a sporting event. It was a fairly draconian short term eating plan that you could only really sustain for a finite time because it basically condemns you to only eating food you’ve prepared yourself (it was surprising how many people on the first idave threads couldn’t cook but hadn’t really realised). It was also a diet which took for granted the fact that you exercise already because his clients are sportspeople. So if Mols is back to his pre-diet weight that may be because he’s not dieting, not the diet not working.
    wanmankylung
    You keep telling yourself that. 😀
    maccruiskeen
    I can if I like. I’ve never been on a diet though. I found the threads interesting because of the recipes that cropped up and the culinary challenge it creates – it set some interesting parameters to cook within, some of which have become a bit of household staple now.
    piemonster
    6lbs
    bearnecessities
    I’ve recently lost 32lbs of pizza & cake in 10weeks. Go me. 😀
    _tom_
    A top tip for this would be to eat less and move more, probably.
    zilog6128
    you say that like it’s a bad thing!!
    miketually
    You could lose 3kg, then buy jeans which will be too small for you by the end of August.
    It didn’t work, long term, for molgrips, but that’s because he’s a precious flower or something 😉
    bigblackshed
    It’s because it’s a diet not a lifestyle change.
    Eat (insert fad food item) and nothing else = drop a load of weight. Return to “normal” and put it all back on.
    Eat sensibly and exercise moderately and you will drop some weight and become fitter. To drop more weight, either eat less or move more.
    There is a whole load of anomollies surrounding eat less / move more, that will give differing results for different people. Some are sustainable, some aren’t.
    I can offer shed based liposuction with a rust knife and an industrial vacuum if you’re desparate. PayPal Gift and no questions. 😉
    Jamie
    I thought he was a unique snowflake?
    andy7t2
    What jeans?
    Only two think he might need his legs
    piemonster
    I always had him down as a ‘delicate sunflower’
    bearnecessities
    Sunflowers are hard as nails.
    Precious Passat?
    hora
    Fasted rides
    Re teach your body to eat fat. I.e remove carbs from diet
    ton
    6lb in 3 week is a good figure.
    poah
    hora – Member
    TBF your body knows how to metabolise fat, it doesn’t need taught lol
    Rubber_Buccaneer
    Forget the weight loss, be yourself….
    binners
    Have you considered the Class A Drugs Diet? Not only effective, but bloody good fun too!
    The only downside is the expense.
    ampthill
    Jamie
    bearnecessities
    It’s ok, he means the inevitable hookers. We all know the drugs are cheap.
    molgrips
    It can get better at it though, like most things it can be trained and improved.
    Aww, thanks 🙂
    It works unless you end up using more carb than you can eat in low-carb form. Which for me was quite easy.
    We ain’t all the same inside.
    ampthill
    I’m not sure mine can
    Well its at a much lower rate than many. We had a few cycle touring holidays when we couldn’t quite get the righy. That split the 4 of us into 2 pairs. The fat metabolisers were out of site…
The topic ‘How much weight can I lose in 3 weeks?’ is closed to new replies.
