On approx 20cm of exposed seatpost?
14.5 stone fully loaded and I've noticed my FSA post really flexes under load and is starting to creak
Would something like a Thomson post really flex any less?
I'm about 17 stone and haven't noticed my thomson flexing or creaking. Quite a thin one as well (26.8mm) and its a good length out of the frame.
thomsons bend/flex aswell .mine does & im only 9st 6.
infact the fsa one on my other bike does too
See that thing that comes up quickly in front of you - trail, road or track - concentrate on that more. I have no idea if any of my kit flexes
_tom is your post used in a HT or FS?
It's in a hardtail.
ally or steel ?
jimmyshand - MemberSee that thing that comes up quickly in front of you - trail, road or track - concentrate on that more. I have no idea if any of my kit flexes
Post of the day!
Glad you liked it.
I didnt think ally was meant to bend much at all
I think you've been reading too much magazine type faux material-science rubbish. All metals flex. Seatposts flex plenty and are usually just fine. I really wouldn't worry about it unless it actually bends (and I've bent a lot of them).
Thomsons flex plenty too.
I'm puzzled as to how you would measure how much the seatpost flexes. As said above, most stuff flexes. If you are genuinely worried then check the post for stress marks. I had a Ritchey post that started creaking badly. When I checked it had quite a few marks down the front.
Hope this helps.
+1
If you really want to shit your pants, buy a carbon post hook your bike up to a turbo trainer and spend an hour marveling at the flex.
enfht - MemberI didnt think ally was meant to bend much at all
I shall use this on the BS of the week thread on Friday.
Does anyone know if the VCLS seatposts are available to buy?
I know they're fitted to Canyon & Cannondale complete bikes but I was looking for such a seatpost with no luck...
edit: by the way - the 34.9mm carbon post on my Scale doesn't seem to bend very much at all. Ouch.
IME;
Bontrager Posts - Light but extremely flexy but never broke.
FSA - V heavy, indestructable, slight flex.
Thomson - Light, slight flex but not as much as the FSA
Thomson - Light,
I shall also use this in the BS of the week thread.
Reminds me of the time when that strange grinding noise turned out to be I'd lost my back wheel.
I know they're fitted to Cannondale complete bikes
Every Cannondale I've had over the past 6 years has come with an FSA post, Although looking at their website they now appear to be own brand or USE
Well, it does take a finely honed mechanical sense to determine that without having a quick glance to check.
To clarify, I believe my very flexy seatpost is creating some occasional creaking so I'm pondering on replacing with either a Thomson or Race Face Diablus post because I'm fed up fettling with carbon paste, different clamps etc.
Indeed
it coudl just be that the seat tube is slightly over/seatpost slightly under size.
Ragley do a 27.3 seatpost now for just such occasions.
Thomson - Light,I shall also use this in the BS of the week thread.
In my experience they are. What's happened to this forum where you put your honest experiences and get shot down for your comments - at least substantiate your comment. I didn't realise the schools had broken up already?
Well said Keiran
Thanks wwaswas I hadn't thought of that
Lighten up, Thomson Posts for e.g 27.2 x 410mm is 290g whilst it's not super heavy it's at least 50g or so above anything I'd consider, their stems are porky as well.
FYI I left school 26 years ago.
If you are using a good quality post, then I don't think you need to worry about it snapping. However, creaking can be VERY frustrating.
Are you sure it's the post ?
From my experience it is usually either: the seatpost to seat-rail, seat-rail to seat, or seatpost to seat-tube interface.
Maybe try stripping, cleaning and refitting them all ?
Set back posts will (like for like) flex more too. I had an EA70, it flexed miles !
Using Thomson's on all of the bikes now. They do flex (it adds comfort) but they aren't going to snap !
(waits for some :-0 to say they snapped one !)
I bent one but it didn't snap
Thomson is great kit, but it sure ain't light. Well engineered kit that lasts, yes. Lightweight, only in comparision to scaff bar.
People takes things awfully personally on here eh what?
The bolts on the seatposts aren't all that IMO.
Can't say I've ever had any issue with the bolts but then I don't reset my saddle every ride with a spirit level like you do KT...
I've had no problems with the bolts on my Thomson either, and I do tend to crank down quite hard on these sorts of things.
True, over faffing and crappy tools probably did for them.
Is that becuase you've over torqued them to deal with your fat ass?
I have had (counts quickly) 8 of them over the years, absolutely no issue. In fact I think thomson use some of the best fasteners I've ever had on bike kit, no corrosion issues, no binding, threads always run clean and true.
OMG TEH IRONING!!!!1111111111LOLLERCOPTERS.
