Viewing 40 posts - 41 through 80 (of 96 total)
  • How much does your 160mm bike weigh?
  • Northwind
    Why do you think a dropper’s essential for the alps? I found mine pointless with the extended descents, barely used it. And then I broke it in a crash! Wouldn’t be without it here but I’ll probably not bother with it next time.
    Coil shock, meh. I had a coil for this bike, but it didn’t add much, and had some disadvantages. Hardly an essential with modern air shocks.
    And duaplies… well, I swapped to the SX carcasses for the endurance dh at fort william this year, they were spot on. So had no worries about taking them to the alps either. Could have wished for a slightly stickier front, mind, but they’re tough as old boots.
    randomjeremy
    My do-everything bike is pretty heavy so I have decided to put it on a diet, no idea on current weight.
    CCDB steel coil
    Saint 2×9 +bash
    Mavic 721 on evo2s
    2.2 RQs with DH tubes
    To:
    CCBD Ti coil
    Saint 1×9 +chain device
    Easton havoc UST
    Hans dampf tubeless
    Back of a fag packet calculations come in at ~3.7lbs saving, mostly from the wheels. Should make it a bit easier uphill at least! Although I’ll probably stick the 721s back on when Alpsing.
    brakes
    2006 Enduro, Marz 66 forks, XT kit, Saint cranks, Thomson. 35lbs with heavy wheels and tyres, 33 lbs with mid-weight.
    Not good for all day rides but did PPdS on it in mid-weight guise and it was perfect. Amazing the difference on character wheels and tyres makes.
    stevenieve
    30lbs
    Carbon Nomad
    Float RLC’s
    2×10 XTR group
    Crossmax SX wheels
    Reverb
    Carbon Haven bars
    Straitline Amp pedals
    Steve77
    Intense Slopestyle Mk1
    Marzocchi 66s
    1×9
    Reverb
    Big tyres and DH tubes
    38lbs. That means I win right?
    thisisnotaspoon
    Spesh Pitch
    Lyrics
    Hope/EN521 wheels
    reverb
    1×10 + silentguide
    About 32lb with pedals on average, under 30lb with SPD’s and a normal post, could probbaly be under 29 comfortably with the OEM wheels and light tyres. Holiday mode depends on the holiday, I think the record is about 38lb with DH bits and the reverb, lightest was the 29lb with SPD’s and conti superonics for a trail center.
    schnor
    Medium Pitch but still air front and rear, dropper post, hope 2 / flows / FR4’s, stubby stem, steel chainrings (2) / heavy cassette, mud / gaffer tape / million zip ties / far too much grease etc = 35.1 lbs.
    It gets a bit heavy when it needs lifting over fences / gates etc at the end of a ride, but I’ve deliberately gone for a (cheap-ish) burly build.
    [edit]
    I’ve no idea (nor care) how much weight its added but I’ve replaced pretty much all bolts / fixings with chunky stainless steel parts, except the m14 axles
    robhughes
    Spicy 516
    Full xt 2 x 9
    u-turn lyriks
    dhx5 coil with Ti
    syncross dp 25,s on pro2,s
    Haven bars and stem
    hayes stroker trail
    ks remote dropper
    2.4 NN evo,s
    34.5 lbs on the bathroom scales so i don,t know what it weighs. 😉
    bennyboy1
    27.5lbs.
    superfli
    31 lb for my heckler bathroom scales
    Xfusion vengeance forks
    Rp23
    single ply tyres
    2x9xt
    Superstar &flow wheels
    Reverb post
    Xt &hope components
    ahwiles
    38.2lbs…!
    mondraker prayer (coil shock)
    domain forks
    bunch of other sturdy things
    it’s ace! 🙂
    The-remedy
    Remedy 9 09
    31.2lbs
    ccdb with ti spring
    stealth reverb
    1×10 xtr
    xtr trail brakes
    36 talas rlc
    rhythm pro carbon bars
    dt ex1750 wheels
    2.4 rubber queens
    superstar ultra mag pedals
    Hob-Nob
    27lbs near enough on the nose. Nomad carbon with Lyrik solo air & vivid air. All light but strong kit
    My Mrs has a Meta SX which came out at 29.9.
    GW
    Light but strong?
    Seriously doubt you can build any 160mm bike under 29lb and keep it strong/stiff.
    Which begs the question, why would you want a weak build on a long travel bike?
    _tom_
    Makes it easier to pedal round Llandegla.
    GW
    Sad but probably all too true
    GW
    Full component spec of some of these bikes would be “interesting”
    jam-bo
    No idea. Lighter than my old DH bike, heavier than my hardtail.
    AlexSimon
    For straightlining down steps?
    Anyway – not everybody is the same weight. I know that at 60kg, I’d want to keep a 160mm bike at around 30lb, with only tyre changes dipping it under or over.
    nasher
    Hey Ewan…swapped the cruz for a mega?
    My mega with…
    Float 36 kashima front and rear
    mavic sx with 2.35 maxxis single ply
    1 x 10
    no dropperpost
    XTR brakes
    nukeproof finishing kit is about 30.5 – 31 pounds (me and bike on bathroom scales) so some margin of error there..
    The new 2013 mega is about a pound lighter so that will be interesting to see.
    Hob-Nob
    Light but strong?
    Seriously doubt you can build any 160mm bike under 29lb and keep it strong/stiff. Which begs the question, why would you want a weak build on a long travel bike?
    Quite easily actually.
    honourablegeorge
    GW – Member
    Hob Nob’s biek seemed to cope OK with the Mega….
    GW
    That’s your benchmark?
    honourablegeorge
    GW – Member
    Not necessarily, but it does counter your suggestion that the bike is only used for trail centres. Obviously it would have to be built a lot more solidly to survive the rigours of the constant trolling on here.
    mikewsmith
    Amazed people have Saint Cranks on trail bikes 🙂
    Someone asked about full Specs so here goes
    SC Heckler Mk6.1
    Fox RP23 From Orange Alpine (Slightly different e2e I think)
    Marz 55 09/11 Hybrids Coil
    Hope BB & Headset
    Easton Vice 50mm Stem
    Nukeproof Warhead Bars
    Hope Tech M4’s on 200mm Floating (Black)
    XT Mechs and shifters – cables no idea
    SLX Cranks
    Middleburn Rings 22-36
    FSA Bash
    Blackspire Stinger
    SRAM PC991 Chain & Cassette (9 Speed)
    Hope Pro II on EX721 (Hoops)
    KS900 Post lever not remote
    Charge Spoon Ti
    CB Mallet 2’s (Soon to be the new 3’s)
    Minion DHF 2.35 Single Ply or HRII 2.4 Single Ply
    Maxxis lightweight tubes
    PRO Endless Grips
    missed anything
    hits around 34-35lb pedals well rides fun.
    Throw some 2.5 Minion DP for alps or down only riding.
    Rorschach
    Its 200mm but it only weighs 28lb13oz
    GW
    ‘d love a shot on that, but hate to own it. ^^
    GW
    George – I didn’t actually make such a suggestion.
    Screaming “troll” the second someone questions/challenges you is pathetic. And a big part of what’s wrong with this place.
    Rorschach
    I’ll thing you’ll GW is a big part of what’s wrong with this place 😉
    GW
    You’ll “thing” me?
    That’s the strangest dig anyone’s ever had at me on here
    mikewsmith
    put it away lads
    Rorschach
    Only if you buy me dinner first.
    honourablegeorge
    No, you merely said it was “probably all to true”.
    And I’d say that a bunch of people automatically jumping to negative conclusions about someone based on a scrap of information about a bike is a somewhat larger part of what’s wrong with this place. “His bike is a bit lighter than mine – he mus be a mincer/doesn’t know how to ride it/etc, etc.” is either jealousy or trolling. Grren face, either way.
    thepodge
    I’d like to thank GW, after two of his posts in any thread I now stop reading as they seem to go off topic and verge on bickering.
    I now have much more free time instead of being on here all the time.
    Ewan
    Your bikes inspired my Ady! For the time being at least – picked the frame up for just under 600, a change is always good. Inital impressions seems to be that the shock is indeed quite a hard tune, but climbs well and jumps better. Quite like it and was fine in nagery singletrack, tho not quite as good as my nickel (that is 3 inches shorter tho!).
    Guess like anything it depends on what you ride when you’re there. Totally agree it’s pointless on the Pleny etc, but on some of the slightly undulating singletrack that’s less well known it’s quite handy. Even when I was in Whistler it was useful ocassionally (riding rom the bottom lift to the bottom of the top lift! Certainly when we rode with Riveriabike they came into their own, that’s more the martime alps than the alps proper.
    GW
    Jealous? 😆 of what?
    havimg a lighter bike takes nothing more than spending cash on lighter parts. Did plenty of that in the 90s thanks.
    lungman
    my covert is 31lbs with
    medium covert
    bos deville
    american classic wheels+tubless
    fox rp23
    1 x 10+e13 srs
    hope tech m4
    reverb+belair t1 saddle
    high rollers 2.35
    xt gears
    have a ccdb for rougher stuff dh
    GW
    Rorsch – KFC do?
    honourablegeorge
    GW – Member
    Jealous? of what?
    Ok, so we can rule out jealousy in your case, then.
    Rorschach
    Makes me guff….but if you don’t mind the smell it’ll do.
The topic ‘How much does your 160mm bike weigh?’ is closed to new replies.
