Well at the moment I have a 32t on an XT M785 crank, with 2mm spacers and 8.5mm long bolts. I also moved the lone BB spacer from the DS to the NDS to get a good chainline.
I’ve got a 30t SS chainring coming to try out, which effectively has the spacer built in for chain/spider clearance, so I was wondering if I could put the BB spacer back to the DS to get the cranks properly centered again, and use the 2mm spacers with the 30t chainring to get the chainline right – if the 8.5mm bolts would be long enough.
If a standard 6.5mm bolt is ok with these threaded 30t rings then I would have thought an 8.5mm bolt would be ok with a 2mm spacer on? Unless there’s something I haven’t considered?
