mikewsmith – Member
Just make sure you remember the difference between Lumens and Internet Lumens
also Chinese Lumens.
Take the number, e.g. some bonkers claim of 9000 Lumens, and knock a zero off it 😉
But largely ignore it and check out test and user reviews to see if it’s the kind of brightness you want.
What you need depends on what you are doing though and whether you ride on your own or in a group, and if in a group what lights the rest of the group has.
You don’t need so much power in a helmet light if you combine it with a good flood bar light, but you want a good ‘spot’ focus in the helmet light. These are things to check beyond just lumens. The lenses in the lights vary.
If you have a group competing for brightest lights, you don’t want to be using dim lights if you’re in front of brighter ones as you’ll be in a shade.
Then again, with a group, everyone can run on medium or even low power and there’s sufficient light amongst you. On your own you might want more power to provide enough light.
More lumens = more power drain, so you want to check the battery is capable of running long enough for the length of ride you may be doing.
And lumens claimed are usually at the highest setting. You generally won’t run it at highest as it will drain the battery fast and get hot. Typically cycle between bright for tricky singletrack, medium or low for fireroads etc.
