1) how on earth did you manage to mangle them?
Bad tool, or bolt head full of mud, most likely. (incidentally, fixers-of-other-people’s-****ups-everywhere- if you do get a stripped socket cap bolt on a mountain bike, before you do anything else, see what happens when you clean the mud out- often it’s only the top that’s stripped, because the owner’s tool only touched the first couple of mm, and you can still get adequate engagement).
Link to previous thread anyone?
90% of the time it’s used on plastic bits (and for some reason, mountain bike brakes)
****ing bastarding mondeo rear wheel bearings, is all I can say to that. T45, special long shaft tool, engaging into a bolt made of rust which has basically welded itself to the hub.
There’s another **** of a torx in a focus front hub IIRC, it can **** off too. It’s like everywhere they found a bolt that was totally exposed to road salt, which you’d only want to remove after 75000 miles, they used a torx. It’s because of that thing I said about Henry Ford’s mum.
