Viewing 8 posts - 1 through 8 (of 8 total)
  • How high is too high?
  • letmetalktomark
    No not this:
    But BB height.
    Looking at using larger wheels in a 26” frame that currently has a BB height of 300mm
    Options for wheels are:
    650b+ wheels
    650b wheels with 40mm tyres
    For those interested this is the frame details:
    There is oodles and oodles of clearance for both options but both will raise the BB height and as its a rigid set up its never going to change.
    As a side thought would a 15mm change in fork length (shortening) – again rigid – have much effect on the BB height? I appreciate it will quicken handling.
    All help much appreciated 🙂
    amedias
    personal preference and intended use.
    but 300mm isn’t that high to start with, so you have some leeway. Give it a go and find out, experimentation is half the fun and will give you a better understaindng of the limits as well 😉
    650B with 40mm tyres will likely be pretty damn close to 26x2in+ anyway.
    FWIW, you can get used to a lot of ‘sub-optimal’ setups quite easily, only you will be able to say when it’s gone too far for you.
    letmetalktomark
    Thanks Amedias.
    The rear will fit a 29+ wheel again with clearance but that increases the BB height by 40+mm – Looked awesome though 😆
    Is it not?
    chiefgrooveguru
    300mm is a nice BB height for many things. Lower is good for bermy stuff, higher is good for techy pedally stuff.
    If I recall correctly my Soul was at 335mm, my Spitfire is at 342mm and my Bird was 295mm and now 305mm – all unsagged. Sagged that makes them about 326, 307 and 296.
    chiefgrooveguru
    15mm change at the fork is about 5mm at the BB.
    letmetalktomark
    amedias
    Is it not?[/quote]
    no not really, it’s a sensible middle ground kinda height, very adaptable to tyre/wheel changes in fact.
    Don’t have exact measurements to hand but I know my bikes vary (currently and over the years) between ~10.5in and ~13.5inch, which is what 265mm to 350mm?
    There can often be ~30 variation between models/brands of the same kind of bike so unless you were at the extreme end and thinking of going further in the wrong direction I wouldn’t be overly worried.
    Also, think about tyre size, people have run anything from 1.8in to 2.4inch tyres on the same bike, that’s ~15mm just from a tyre change on the same wheels, so a bit more leeway in either direction isn’t a big deal.
    Add to that the fact that a smooth trails/moorland wanderer will get away with a lower BB than someone who regularly has to pedal up and along deep rocky/rutted type trails and you can see that ‘optimum’ height isn’t a static thing
    People get far too hung up on BB height, especially on HT/rigid bikes, unless you’re talking right at the extremes of height, extremes of terrain, or extremes of performance then it’s into the realms of insignificance.
    I say crack on with your experiment (whatever it is) and have some fun 😉
    letmetalktomark
    “gravel bike” natürlich 😳
The topic ‘How high is too high?’ is closed to new replies.
