Viewing 2 posts - 1 through 2 (of 2 total)
  • How hard is it to wire in a new consumer unit in a caravan ? Electricians
  • unfitgeezer
    The original unit is from 1987 with no RCD and probably isn’t up to standard so I’ve purchased one of these
    This unit is caravan specific double pole , I’ve looked at the old one and there are four wires going into it which are lights/fridge and plug sockets, its looks fairly straight forward to actually wire in or should I pay an electrician ?
    6amps for fridge and lights
    10amps for plugs
    thoughts ?
    nickjb
    It’s a pretty straightforward job. Connect the wires to the right bits and make sure you have a good connection. Isolate before and test it afterwards.
The topic ‘How hard is it to wire in a new consumer unit in a caravan ? Electricians’ is closed to new replies.
