Hi, I recently had to fit new pistons on Juicy 7’s having cracked a piston whilst trying to push it back in to fit new pads. I was dubious about how easy this would be, but found it quite straightforward. The hardest part is rebleeding after fitting even with the Avid syringe bleed kit.
You have to take the two halves of the capliper apart. You then need a source of compressed air to force the pistons out. The manual recommends placing the caliper halves in a bag to catch the pistons – I didn’t do this and wish I had becuase when they pop they go with some force.
My tip is as follows – you will need a track pump. Then you need a means to connect this into the fluid cavity in the caliper body. I found taking one of my children’s felt tip pens and pulling out the back part which holds in the ink worked. Cut the ends off and place this in the track pump. Then force the other end into half of the caliper body. Assuming you’re working alone, hold the makeshift air line on place with one hand and pump with the other. The piston will soon come out as the pressure builds. One half (outboard I think) of the caliper will have a hole straight through both sides so you have to cover one side with you finger and press hard with the air line in the other side.
Getting the new pistons in is easy – just remove the old rubber O rings and fit the new ones in the piston kit, then lubricate these and the piston bodys – either user brake fluid or a little silcon lub spray.
Then reassemble, add fluid and bleed.
Good Luck
Neil
