I know that there’s a lot of you handy types on here, in fact, i’m blaming you for the inspiration to have a go at this bloody project in the first place, so it’s time to pony up some advice.
The mess that i’ve made so far can be seen below, there used to just be a hardboarded in area where I made the hole, there’s a gas pipe running underneath, hence not just screeding the floor level.
I had planned on sticking a sheet of ply across the front, cutting out a door shaped opening and using the cut out bit as the door. I suspect that it’ll look a bit crap though and there’s a better way to do it.
Alas, as you can probably see from the effort already, i’m not that handy – what’s the best way to go about it?
Cut a hole in the ply and make a little tiny door frame out of beading? I’d
