Disassemble, degrease and check bearing tolerances carefully, if they exceed manufacturer’s specification then replace. Or… notice the cranks are moving up and down as well as round and round, which is generally a bad sign.
‘Dead’ things are generally pretty obvious aren’t they? And the latest spec HT2 bearings, which I presume are what you have, last an awful lot longer than the old ones, so just because they’re a year old, doesn’t mean they’re fecked. You can always very carefully pop off the plastic top-hat things, use a pin to remove the bearing seal, clean with WD40 and re-grease if they feel gritty but have no play.
But if they go round, don’t make weird noises or display obvious symptoms of wear, like play, I’d just leave them to it and go riding 😉
