Bent Udder – I see that you are correct. I was in a rush to find a new frame when my old one broke. I didn’t notice that there was a V2.
BTW – what are the ‘swapouts’?
you said “the most modern version has swapouts”
Regarding Kona Scandium frames, mine broke around the seatpost where it meets the top tube.
I did i bit of Googling of Scandium frame repairs and it seems that you need to use filler rod made of the same material otherwise you will not have a strong enough join due to Scandium frame tubes being thinner than standard alloy.
I figured that the cost of a repair would be at least half the price of a new On-One frame and I wanted to try newer geometry.
My seat tube max-height mark was about an inch into the frame.
Regarding the On-One frame sizing & seatpost:
On-One recommended 19.5″ for riders 5ft 10″ to 6ft 2″. I am 5ft 11″ (31″ leg) and have had to get a BBB Longscraper 450mm seatpost to avoid another frame break.
There aren’t many choices in seatpost if you want 450mm or more. The BBB longscraper is the cheapest I found at around £23 but it is a bit heavy.
I wanted to make sure I had a couple of inches inserted past the top tube.
The ScandAl has the ‘New’ tapered head-tube so to fit my old 1 1/8″ steerer forks I fitted an On-One Smoothie Mixer headset.
This works straight out of the box with 1 1/8 steerer forks.
I bought the reducer collar for tapered steerer just so that I have one for later (it was £9.99 then – not £19.99 as today)
smoothie mixer headset
I dread the thought of having to remove it in the future as it has more contact area on the frame.
I don’t think my basic 1 1/8 headset removal tool would be beefy enough
to knock that out?
