as above really, I know some SIDS are adjustable to 120mm? I dont think mine are but I know they can do 80mm, how do i tell if theey can go to 120mm?
The are Rockshox SID Teams 2009, in red/black.
Strip out the air spring and see if there is a 20mm spacer on it, 10-15minute job if you know what you are doing.
There are 2 slightly different forks: 120/100s and 100/80s - if yours go to 80, they won't go to 120. They're a very slightly different design.
better put the spanner down then as mine definitely go to 80mm.
Only 120mm from 2011 onwards too.
You must log in to post.
