trail_rat – Member
how many pots you got…..
ive got three pots – and ive got 3 fire places.
upstairs bedroom is the middle pot. living room is the front pot and the kitchens the rear pot.
all three condense into an area around the upstairs fire place fairly closely – if you didnt know it looks like a single chimnney breast. – my living room one strafes across the wall at a steep angle to do so – you can see the alcoves boxed in to allow it to do so.
sounds similar to yours.
Thas probably answered my question. So our house is an “L” shape with the kitchen/diner at the top of that L on the bottom floor, and my daughter’s room above it.
There are two pots in the adjoining chimney, I guess one for us one for the neighbours. I had a look in the loft and the chimney goes straight up from my daughters room. There is no stack(?) to the left of it where the downstairs chimney is, and no signs of any work beyond the original brickwork.
The odd thing is, the “faux” chimney is of solid construction (determined via a knock test) and the space above the fireplace has a more hollow less solid sound – as if it WERE a fireplace which has been blocked.
Why would you build a chimney for effect so solidly and so effectively fake?
