Look for a reba service guide. Should be videos on you tube and documents on the sram site as well as forum guides.
You have a small quantity of lower leg oil in each side. This will need to be drained out and replaced – it is probably too low and dirty anyway.
You then need to remove the air spring piston (split ring on the bottom of the stanchion inside the fork) and the spacers are obvious on the shaft.
You will need to put a quantity of new oil in the air spring and then in each of the lower legs on assembly and are supposed to fit new crush washers. Really easy job but you will need some of the correct oil for lubrication.
