paulneenan76 – Member
You’d have to do it manually i think. If you classified your commutes as “commutes”, which is an option, you might be able to see a running total. Why dont you just add up a typical month and multiply it out?
Also, you dont wear a bike out, you might wear out components which would need to be replaced!
Nope, i’ve worn the bike out, i’ve done 8192 miles in the year of commuting in every weather on my Specialized Roubaix, none of the original components (came with 9 speed Sora) have survived, it was gradually upgraded with 11 speed Ultegra and Stans A400 wheels etc, and whilst some of the components are still fine form the upgrades. eg the Hope hubs from Stans wheels are about to re-rimmed with Grail rims etc, the actual frame itself it really pretty tired, there are deep scratches in the carbon, bottle cage bolts spin in the frame and there is now noticeable flex in the steerer as i stand up and honk it.
So bearing in mind the frame is very tired and every components has been replaced at least once, i’d say i’ve worn out the whole bike (doing Paris Roubaix didn’t help!!)
