Viewing 40 posts - 1 through 40 (of 70 total)
  • How different are your bikes?
  • molgrips
    In other words, how much of the bike spectrum do you have covered?
    At one end I have a Dolan Precursa track bike, at the other a Patriot 7+ (albeit air sprung).
    weeksy
    Not much,
    I have an HT29er and a FS29erAM.
    They’re similar but different enough cover every single base I am able to ride really well..
    maximusmountain
    At one end I have a karate monkey set up as a drop bar road/cross bike (lovely mud clearance) and at the other end I have an SS Pugsley. Inbetween I have a rigid 29er set up as 1×10. Not all that different to each other if I am honest.
    Northwind
    Quite similiar I suppose in the grand scheme of things- flat barred fast hybrid to lightweight 6 inch #enduro steed via long travel hardtail. The 2 mtbs can both easily do the job of the other, just differently.
    akira
    Madone to a Fatty so a reasonable spread, with a few things inbetween obviously.
    stevied
    All of my bikes are exactly the same. I only have one tho 😉
    scaled
    Carbon road bike and 140mm hard tail, the 170mm full suss should fit in the spectrum quite nicely when it arrives in Jan 🙂
    Junkyard
    one of each
    FS
    Hardtail
    SS
    Road Bike
    Hack Bike
    Anything else and you have a bike that gets limited use IMHO or you are getting a niche bike. Even at that every bike is not ridden every month and I ride 3-4 times a week
    PeterPoddy
    26in MTB tourer
    CX
    6in AM bike
    Steel hardtail
    So, all usable off road to different degrees, mostly steel, mostly 26in.
    jaffejoffer
    1 x hardtail
    1 x full suss
    both 27.5 and 160mm.
    1 x unicycle
    also have a bike that i go to work on but that is a road bike or something and they dont count.
    mikewsmith
    Mountain bikes range from Race ready 29r to Full on DH bike
    karlwoof
    CX Bike
    Summer Race Bike
    Winter Hack
    Turbo Slave
    140mm FS
    Think i’ve got all bases covered 🙂
    convert
    Mines a triangle of variation – full suss mountain bike on one point, disc wheeled full on time trail bike at another and recumbent tourer on the last. 5 other bikes occupy the middle of the triangle.
    Kind of feel I have most of the pedalling world covered.
    Royston
    Road bike
    FS Aluinium 26″ mountain bike
    Singlespeed Steel 29er HT
    and soon to be aquired tourer/adventure bike in the form of a ‘Kona Sutra’
    Nearest are the cross bike and the road bike cos they have drop bars and 10×2 gears.
    MTBs are
    5+” travel full sus – 9×3 speed gears
    A steel hardtail – 8×3
    A rigid singlespeed
    so all pretty different I reckon (apart from the mtbs all having 26″ wheels).
    oliverracing
    700c road bike 2×9
    700c cross bike 1×10
    26er homemade carbon monstercross singlespeed 1×1
    26er homemade carbon XC full suss 2×10
    26er Steel/Ti retro mtb/tourer (currently in pieces) 3×9/10
    So I guess not a bad range and all have different gearing combinations!
    I think I’m definitely in need of a 29er to compliment them…
    rumple
    quite a lot, 140mm full sus, 100mm jump bike and a road bike.
    i feel that that’s all i need (im clearly lying)
    rocketman
    Not much
    100 mm DJ HT at one end and a 200 mm DH FS at the other
    A fair bit of interchangeable componentry means I can make any one of them into something else
    There’s a road bike as well but we don’t talk about that
    njee20
    Not much. Road bike to 29er XC hardtail.
    thegreatape
    A 2×10 650b fun hardtail and a SS cross bike.
    honourablegeorge
    Steel commuter – steel 140 ht – 160 FS – 200mm DH
    jimw
    24 lbs to 31 lbs
    chestrockwell
    2x retro rigid, both 1989.
    26″ 100mm HT.
    29″ 140mm FS.
    zippykona
    Raw,grey,yellow and green.
    ska-49
    140-160mm FS 650b
    120mm HT 650b
    Rigid SS 29er
    CX bike
    [Commuter]
    Good spread I think.
    ChunkyMTB
    650b Alpine muncher
    29er short travel
    CX
    velocipede
    mmmm, mine are a bit close for comfort really – hand built modern steel road bike with 10 speed ultra, alu & carbon road bike with 9 speed tiara, and a hard tail 29er XC bike…..
    I could really do with a cross bike and a full sudser but budget won’t allow!
    LoCo
    CX bike to BMX
    everyone
    Steel 650b XC hardtail 1×10
    Scaffolding 650b rigid SS
    Road bike 2×10
    Thinking about getting an old steel road bike and a nice 650b/29 SS, maybe Ti but probably steel again. Or maybe carbon. Wouldn’t turn down a CX bike either geared or SS.
    BoardinBob
    Steel 650b hardtail with 140mm travel
    26″ 160mm “enduro” full susser
    26″ 200mm downhill bike
    tazzymtb
    All rigid singlepseeds, all very different to ride from a floaty light niche titanium thing, a jones space frame, a stooge, etc..through to a fat bike.
    I’m sure one day I may get an urge for boing or gears again, but dont see the need
    tomhoward
    Fat bike
    to
    Carbon road bike
    to
    steel singlespeed MTB
    to
    Carbon 650b 165mm #enduro gnarpoon.
    plus a couple that fit inbetween.
    17-29lbs
    Lots of variety if you ask me. However, to the non initiated, I have 6 ‘bikes’ which is pointless. Apparently.
    ChunkyMTB
    tazzymtb – Member
    None of that is niche anymore though, niche is dead 😮
    You’re gonna have to try harder!
    cynic-al
    Cannondale Supersix through 3 others to a fat bike (and full suss on the way) with a Brompton too.
    All get used too!
    Never seen the point of having similar bikes.
    xiphon
    Race BMX
    DH bike – 224
    Rigid P7
    Road bike
    AM/XC – Patriot ’00
    Fairly varied I think!
    Scapegoat
    Alu road bike through steel hardtail to carbon 140/160 full suss
    oldschool
    When my wife asks, they are all very different. Each has a specific use and can never be used for a purpose not intended, hence the amount of them. In reality they all have two wheels and handlebars and if it was the 90’s I’d be made up with any one of them. DH, 150mm FS, XC FS, jump, beach cruiser, BMX, SS. Need a ride bike though.
    I_Ache
    26″ Stumpjumper
    26″ BFe
    29″ Solaris (under construction)
    Bianchi road bike
    I think that is a good spread and I don’t really want anything else.
    tonyd
    In approximate order of weight:
    Road bike (carbon)
    120mm FS (alu)
    90s hardtail (steel)
    Drop bar commuter (steel)
    paule
    Fairly wide spread:
    Pompetamine set up as a hub geared, drop (flared) bar commuter.
    Longish travel ht xc bike with pikes up front.
    Maverick fs bike (again with pikes)
    Unfinished thrashing bike – 150mm travel ss hardtail (duncon cock) with chunky tyres, dh wheels and z1 forks
    Hopefully getting my old ti road bike back in the spring so that’s pretty close to a full spectrum. Might amalgamate the two xc bikes into a ns eccentric as neither gets enough use really.
The topic ‘How different are your bikes?’ is closed to new replies.
