I am aware that there was a similar thread recently but my question is about too much tension rather than not enough.
I am running 36/16 SS in a geared frame with weakish down-push singulator thingy. Chain (KMC Gold 9/10 speed) kept slipping 1 tooth in peak high-torque uphill situations.
I took out 1 link today, now I am worried that the chain might be a little too tight as I can lift up the chain only 0,2 inch/5mm and even that needs some pressure. Turning the cranks backwards I can feel the tension (slight *whirr* like moving from 1 teeth to the other), but it's not a huge resistance, i.e. I can easily turn the cranks backwards with 1 finger. Giving the cranks a good push they will rotate 1 rotation backwards before stalling (some of that surly also due to resistance in (newish DT Swiss) hub). You get the picture.
A friend reckons that it's OK and that the chain will stretch that micro-bit to make it totally OK after one ride.
Do you reckon I found the magic chainring/cog combination (no need for singulator) for my bike and everything will be just fine?
Or am I about to trash my drivetrain?
