Presumably you are limiting yourself to 30m2 so you can do it as permitted development without having to go through planning? For a garage, planning should not take too long as it should go through under delegated powers, especially if there are other nearby properties with similar. You could do it as a kit build and use the manufacturer's plans to submit for planning.
You also want to make sure it is the right size to add value to the house when you sell it, so it needs to be able to take a car. Assume 5.5m l x 2.5m w x 2 h for a car. If you want exactly 30m2, your optimum would be 5.5m l x 5.4m w – a true double garage. Do what we did and split it down the middle – with one half for the workshop
