Viewing 40 posts - 1 through 40 (of 58 total)
  • How big is your ring?
  • scotlandthedave
    XX1 – how many teeth up front?
    coogan
    Neb
    pbooker1995
    34t on a 27.5″ wheeled bike.
    shortcut
    32 with a 29er and 40 on the back.
    scotlandthedave
    i was thinking 30 as i think the general consensus is to keep it out of the 42 tooth on the back i think and i dont think i’d be doing myself any favours with a 32. expensive decision!
    garage-dweller
    Man up (or get small old school wheels) and go for a 34 front and back
    By the way I live in the south…and may have a bail out granny ring fitted behind my 1x….
    Edit sorry blatantly unhelpful as failed to think about the xx1 reference.
    aP
    30, but my frame won’t allow anything bigger, so only option. 29er.
    andylc
    scaled
    32 on 27.5 (Peak district)
    I’d like a 30, but it’s not bad enough for me to put my hand in my pocket
    roverpig
    Tried a 28 with a 42 out back on a 29er, but it wasn’t low enough for my liking, so I’ve gone back to 2×10 ! Might try it on the 26″ bike though.
    njee20
    32 on 29″ wheels.
    maxtorque
    30/32 depending on where i am riding (26 with Big tyres)
    (easy to change rings in-situ with xx1 😉
    mjsmke
    32 with 10-42 x1.
    etsxteam
    32 with 42 at the back on a 27.5 but thinking of getting a 30 to releve the knees a bit
    nairnster
    32 with a 36 out back, 27.5 hardtail.
    Pridds
    beano68
    30 on my 29er and what a difference … finally
    climbingkev
    1×9, 32:11-34, Peaks District. 26 wheels. Legs wasn’t the issue for me (well maybe a little, but not as much as I was expecting), more a mindset and approach thing. You’ll be reet! Just got some SPD’s, and some winter/injury turbo fitness so might even stick on a 34t oval in the summer. I’ve found myself wanting a higher gear more often than a lower.
    tomhoward
    30 on fat 26er (XO1)
    32 on normal 26er (X1)
    32 on 650b (XX1)
    34 on 650b (XX1)
    Slight hijack, if I were to change from the 34 to a 30, do I have to shorten the chain?
    mikewsmith
    34t 11-40, probably better with 32t.
    iain65
    Just ordered a 32 on a 29er, mates just got his 29er with a 36(!) on it, but he does have an FTP of 385watts so I guess he’ll be okay….
    jamj1974
    robj20
    bol
    32t on 29″ wheels. I have a 30t to drop on for big weekends.
    stewartc
    30 at the moment as its winter, but usually 28
    njee20
    Still an odd choice, unless he’s doing a lot of road riding on it.
    iain65
    njee20 – he based it on his cross bike.
    njee20
    Not so much odd as daft then.
    fatboyjon
    30 x 11/40 on burly long travel 29er hardtail.
    32 x 11/42 on short travel xc 29er hardtail.
    samuri
    Blimey, the world of mountain biking has clearly passed me by. A 42 tooth on the back! What are you guys riding up?
    njee20
    32/42 is a comparable gear to a 22/28. Not that low.
    samuri
    Well that’s a debatable point but I’m assuming the little cog on the cassette is very little to give people a proper range?
    faustus
    32 on 29er, but is a bit too small, will prob move to 34. 11/36 cassette.
    36 for 26er was perfect when I had it.
    zinaru
    34 then 32
    all with a 10 speed 11-36
    its very hilly here
    njee20
    How’s it debatable, it’s basic maths? 😕
    It’s a 10t on SRAM cassettes, a 320% range.
    samuri
    “Not that low” is a debatable point
    njee20
    Well it’s not quite as low as folk running a triple will have, which was my point. You were implying that a 42t sprocket would give some insane low gear.
    robj20
    Debatable, lol not really.
    11-36 x 34
    0.9 – 3
    10-42 x 30
    0.7 – 3
    10-42 x 38
    0.9 – 3.8
    =10-42 wins
    The 10t makes a massive difference.
    On the low side a 28 x 42 is the same as 24 x 36
    dirtyrider
    34t xx1 on Tallboy
    32t xx1 on Krampus
The topic ‘How big is your ring?’ is closed to new replies.
