Viewing 4 posts - 1 through 4 (of 4 total)
  • How are stanchions fixed in forks
  • trout
    wanting to remove the stanchions and steerer from some Rockshox Revs
    and make a new crown with a view to fitting them on the fatty
    just wondering how they are fixed in
    teethgrinder
    bonded, with a possibility of a heated crown and frozen stanchions.
    maximusmountain
    You won’t get a decent re-bond either, your best bet will be pinch bolts like on dual crown forks. If you smack it with a hammer enough times it should come out but may damage the steerer, no idea how you would get stanchions out but “carefully” is my guess.
    JoeG
    If you’re making a new crown anyway, I’d make 2 cuts in the crown to release each of the pressed in pieces. If you got both cuts nearly through the crown, a sharp blow may finish the job by cracking the crown w/o cutting into the stanchion/steerer.
The topic ‘How are stanchions fixed in forks’ is closed to new replies.
