Hello Fountain of Knowledge.
Our bathroom lights have been playing up ‘for a while’. There are 5 mr16 flush fitted spots in a tongue and groove cladded false ceiling: above the tongue and groove there is a void, then chipboard, then insulation then the chipboard loft flooring. The lights have been dimming and some going out.
I delved in today and discovered there are 2 transformers one powering 3 of the lights and the other powering the 2 other lights. The 2 transformers are split from a single power source in the middle of the ceiling.
The wires to the lights from the transformers is all bodged together with quick connectors taped up and the termination from each light is the same. The cable is multi strand 2 or 3 core (I can’t remember) mains rubber type flex.
Sourced the issue to one of the transformers. it has a scorch mark on the case and is buzzing.
The fittings are in 66mm holes but for bathroom fittings it looks like they are all 76mm so I will have to drill the false ceiling holes to suit.
Now. Do I. replace all fittings and transformers with a single 30 or 40w transformer leaving the flex through the suspended ceiling in place.
Or do I replace all fittings and transformers with one transformer per fitting and replacing all the wiring from the single power source probably having to lift the loft flooring and still having a fight (possibly impossible) to thread the cable: it feels like it is either clipped in place or threaded through presumably false joists.
Looking at online suppliers it looks like most new installations would have a transformer/ driver per light. I have found a 40w transformer/ driver here: linky]click meit’s IP67 so maybe overkill to be fitted in the void and would plan to run 5 3.w bulbs of it so it isn’t loaded heavily.
I guess what I am wondering is how much of a bodge is it to do the single transformer to save the hassle of replacing the wiring….
