We have just had the asbestos ceiling removed from our integral garage, and now need to insulate between the joists before fire boarding the ceiling. The bedroom above is cold and musty due to the cold sink of the garage below, so we want to improve that.
There is also a triangle section void above the garage door, as the garage in longer than the bedroom above. This void is formed by a 45 degree slate/lime mortar section of roof, and the plasterboard wall of the bedroom. There is currently no insulation in this void either.
Questions:
What is the best product for between the joists/ below floorboards of the bedroom? Friend recommended thermafleece, which can be handled without Ppe but seems expensive? Standard knaus rock wool type roll? King span?
Should the insulation butt up to the floorboards or should there be a small gap? Edit, joists are 150mm deep.
For the roof void, should I insulate the back of the plasterboard wall (king span?) or the back of the roof slates, or both?
Sorry for all the numpty questions. Cheers!
