I am aware that everything is subject to site conditions, and the quality of the original building, however we’d like to build out the back of the house to make a dining kitchen / lounge.
As far as I can see, we have 2 options, but its difficult to determine which is the cheaper. The house is a 1930s semi, about 5 metres wide. A 3 meter wide by 2 metre deep extension has already been put on to the back of the lounge.
Option 1 = demolish / re-use existing extension and put a 5 metre wide by 3 metre deep (overall when finished) extension on the back giving me a large L shaped space and the original kitchen to be used as a utility. AFAIK no strucutral work required. Would it be fair to say that the only real cost to consider is a new roof for my existing extension and disposal of new walls? Therefore I’m looking at 9m2 of new extension, plus 6m2 of sloping roof?
Option 2 = Add a small extension (2×2) to the back of the kitcehn so that it matches the existing extension, then knock through internal walls to make one large square space. Lots of structural work, leaving a column about 1/3 of the way across may make things simpler (on to which beams can be supported) and could form part of the kitchen design.
I’m thinking option 1 is the best plan as it gives me the most space in the end, and the potential unknown cost of all the structural work for option 2 and risks make the cost differences almost negligible?
