Viewing 3 posts - 1 through 3 (of 3 total)
  • Hope TRex 40t
  • DaveE
    Will this work on a 1×9 set up with a short cage mech.
    pugster007
    Nope, not without a bodge.
    Designed for 10 speed, remove the 17T cog if using Shimano XT mech.
    cookeaa
    Should work if you can tweak the spacing, might still work without:
    9 speed spacers = 2.56mm
    10 speed spacers = 2.35mm
    The t Rex looks to have a wide base from what I can tell effectively integrating that spacer, so you need to find a way to add ~0.2mm, time to break out the tin snips and old coke cans methinks…
The topic ‘Hope TRex 40t’ is closed to new replies.
