Thinking about making this switch for a summer Europe trip. Is M4 really a big step up, having extra pistons and all?
in the past I’ve found the X2 calipers OK mostly, but I’ve needws to go to 2 fingered braking at the end of the day and suffered with some arm pump (….other causes I know).
I’ve stuck a 203mm rotor up front already which should help.
And where do the V2 calipers fit into the product line, I’m a bit confused. I want to stick with Hope as I have the tech levers and floating rotors already, so would just be swapping calipers to save money.
cheers
