Evening all, after a little help please..
I recently purchased the above brakes, F&R to replace some ancient Mini’s I’ve got on at the moment, not realising that I’d require some adapters – the new calipers are post-mount, and my frame and forks are IS.
I’ve been having a look around and found a Hope ‘J’ adaptor, which should be front brake IS to 183mm post-mount.. hopefully.. can anyone confirm I’ve got the right one?
Also I need an adaptor for the rear, but not sure which one I’ll need?
Frame is a Mk1 Ragley Blue Pig, Forks RS Recon 351 Solo-Air, I bought a 183mm front rotor and 160mm rear, any help appreciated..
Thanks, Ben
