Got the big bike out this week after not riding it much over the winter, and the rear wheel is sort of siezed. Very reluctant to spin forward or back in the bike.
Fearing some free-hub problems, I removed it and cleaned all the pawls – everything looks fine, bearings seem OK, basically the freehub is working nae bother. Put it back in the bike and it’s the same problem – something is binding when the (12 mm) axle is tightened up. Any ideas on what that might be?
Maybe the hub end caps? Basic question, but is the hub meant to rotate independently of them once they’re clamped up on the bike? So the wheel should spin completely freely off the bike if you hold it by the end caps?
