Please mail Ahwrigley@gmail.com. All prices posted recorded. Lots more hi res pics HERE
Hope wheels. ProII 6 bolt disc hubs on DT Swiss 5.1D rims. 32 spoke. QR front and rear. Hubs perfect. Freehub perfect. Rims true, with less than 1/2 mm out of true. Few scratches to rims (see link for pic of worst) but nothing serious, no cracks, or flat spots. Very tiny dent on rear rim, but too small to photograph and I only found it by running my finger round the rim! £165 posted or £150 collected from Berkshire
Will split also. Front £65 posted/£55 collected, rear £115 posted/ £105 collected.
P1010381 by carlos_fandango, on Flickr
XT rear mech. M771 9 speed top - normal. SGS Long cage. Near perfect condition. Fitted early this year. Only removed because new frame needs shadow mech. £34 posted
P1010388 by carlos_fandango, on Flickr
XT front mech. M770 9 speed. Top swing. 34.9 clamp. Can provide 31.9 or 28.6mm adaptors if needed. Again near perfect. Only removed as new frame needs bottom swing mech. £17 posted.
P1010387 by carlos_fandango, on Flickr
Middleburn square taper cranks. 175mm long. Silver. Includes lock ring. Pedal threads and square taper holes are perfect. Few cosmetic scuffs. Will also provide the park tools lockring tool. Cam also provide a UN54 bb if needed. £60 posted.
P1010400 by carlos_fandango, on Flickr
Middleburn Uno ring. 32 tooth. Cant remember if 1/8" or 3/32". Pretty worn with hooking starting to show on teeth but still works with a new chain. £10 posted.
P1010406 by carlos_fandango, on Flickr
Hope stem. Black. For 31.8 bars. 100mm x 10 degree rize. Anodizing has worn a bit in places. £25 posted.
P1010402 by carlos_fandango, on Flickr
Shimano deore release skewers. Fitted once so near perfect apart from a tiny scuff on the front. £10 posted.
P1010407 by carlos_fandango, on Flickr
