Right then
Firstly the man on the video on the hope website already told me so…
I had everything out and cleaned
Greased the bearing housings and popped in the drive side bearing – easy
then trying to put the axel in in popped out- no worries I pop it back and give in a tap(read into the what you will) but I dont have the proper flat plate thingy so it gone in a bit squint, knock in out and try again but can't get it to sit right.
So I try a little more enthusiastically with the hammer and bugger up the bearing – not sure where it landed after I removed it and tried to put it into orbit.
On further inspection there is now a tiny ridge in the drive side bearing housing
how bad can it be?? Sending my GF to the LBS to see if they can pop a fresh one in for me
