Hi all,
I have a Hope Pro II Evo rear hub using an XX1 freehub. I have been using this fine with a QR skewer but now use a frame with a 142×12 “E-Thru” rear axle.
I bought the “12mm bolt thru” conversion kit from CRC but it does not appear to fit correctly since the 10t of the XX1 cassette is almost in line with the edge of the adapter (i.e. no room for the adapter to sit in the dropout) and it also seems to be too narrow overall.
Am I correct to be using the “12mm bolt thru” kit for an E-thru frame or should I have ordered the “X-12” kit? If not, I noticed the CRC page said extra spacers were needed to use the X-12 kit with XX1 and I wondered if there might be something similar needed with the 12mm bolt thru kit perhaps?
I’ve emailed Hope a few days ago without any reply. Before I give them a call I thought I’d try the STW massif to ease their workload 😀
Any help you can give to get my XX1/ Pro II Evo hub working properly with my 142×12 E-Thru frame is very much appreciated!
