I bought a set of Hope Hoops a short while back and fitted the 20mm adapter to the front wheel. I’ve noticed a slight amount of side-to-side play (maybe about 2-3mm) in the wheel when it’s fitted to the forks (Fox 36 TALAS), even when tightened as far as I dare.
When the wheel is off, there’s quite a bit of play in the 20mm adapters on both sides of the hub. They are able to move around 1-2mm from side to side (as you look at the hub from the side, so looking down the axle), and about the same movement in and out. I’m pretty sure the O-rings are fitted properly.
I’ve just rang Hope who say they’ve not had any other similar enquiries, so I’m now wondering if what I’m seeing is normal.
Before I send the adapters off to Hope, can any fellow STW’ers share whether their wheel has a little bit of play from side to side, and whether their 20mm adapters have movement when not fitted to the fork?
Many thanks in advance.
Kevin
