Hi,
It seems I need to replace the bearing on the above hub, as there is some play. I'm a bit confused about what hub specific tools I need to:
a) get the bearing out and strip down the hub and
b) to drive the new bearing back in.
I've got normal tools, but have never replaced a hub cartridge bearing
Do I just need the Hope Bearing Support Bush Tool, or do I need the Hope Pro 2 Seal Tool (can't find a Pro 3 equivalent… but the same hub is it not apart from disc mounts?)
Also what Hope Specific tools do I need to strip the freehub down (bearings are ok, but would like to service the free hub.
Many thanks in advance. I've looked on the Hope website but most of it is for Pro 3, and rear hubs only.
