Viewing 4 posts - 1 through 4 (of 4 total)
  • Hope pro 2 rear hub
  • tails
    I have a hope pro 2 rear hub with a quick release. Can the quick release be changed for say a bolt/threaded axle for use with slotted dropouts? Thanks
    foxyrider
    Yup – just get a conversion kit – I got a 10mm but You can get 12mm 15mm and 20mm IIRC 🙂 Got mine from UKbikestore or CRC 🙂
    You need to pull out one bearing and the axle to do it but its fairly straight forward – see here
    thomthumb
    i've got a 12mm conversion kit and axle for sale…
    fits on an inbred (due to slotted axle) i assume it'll fit other track ends…
    tails
    thanks guys I have not bought the bike yet so I'll keep you in mind thomthumb
The topic ‘Hope pro 2 rear hub’ is closed to new replies.
