Some one posted on here with pics not so long ago on the options of how to do the above. I cant believe how flexi the back end of my bullit is with a hope QR in it. I know you can get the 150mm drop outs for it but as I only use it once in a blue moon for uplift days or alp trips, I cant be arsed at the mo to get a new hub and build. Any advice much appreciated.
Bike Forum
Hope pro 2 135mm QR stiffening up options
Posted 3 years ago #
You want a 10mm bolt up conversion..
Posted 3 years ago # -
what about a 10mm bolt thru axle - any better?
beat me
Just had a butchers at crc and it looks like £19.99 for the hope kit and £12.99 for a saint 10mm axle. Does that sound about right?
Sorry to be jumping in but what can be done to a Prophet? The hub can be converted to a 10mm thingy, but will it fit?
10mm should fit in regular QR dropouts no problem.
Forgive my ignorance but what has the axle got to do with the mech?
The older Saint rear mech bolted directly onto the threaded end of the wheel axle- giving a strong and stiff setup with no need for the frames mech hanger to get damaged.
Ah ha.
So any recommendations on an axle or just make one out of stainless.
are the bolts the correct size for "normal" dropouts?
Which bolts?
the ones rock3 linked too
What would they thread into and I dont like the idea of the thread being load bearing on the drop outs. Surly a solid thru axle would be stiffer which is what Im trying to achieve.
Just a thought, could I not drill out the existing adapters and just get an axle?
think about the dropouts - how big are they?
Uh?
jeez
If I convert the hub to 10mm axle, what should I use to hold the wheel in dropouts? The bolts?
yup - got it
Cheers, Ralph. BTW Is it difficult and messy? Do I need any special tools?
big hammer and socket should be about right - same as servicing the hub. see the hope site for instructions on that
Thanks a lot!
Try this..
http://www.dtswiss.com/Products/Components2009/RWS/RWS-thru-bolt.aspx
I'm about to do the conversion on my Orange 5 but will need to wait a couple of weeks until Hope have more conversion kits ready.Posted 3 years ago # -
Hey swede.
Just get the bolt in rear axle and the Hope bolts.
Much cheaper.
swat's on me Nomad.
To confirm:
You can convert the Pro2 to take either a 10mm bolt thru, or a bolt-on (two bolts screw in from each side).
For the bolt thru option you can use either a 10mm DT RWS (which comes with the axle and a nut for the drive side, or a Hope 10mm Saint axle an old Saint mech, or Hope 10mm Saint axle and nut from the hardware store for the end.
10mm axle fits thru standard QR dropouts.
OK so I get the bolt thru option. But could you spell out the bolt on option for me?
SS Stu do you have a Hope 10mm Saint axle......and what?
Ed.
It's a bolt up axle and 10mm bolts.Different to the bolt through axle.
It was posted up earlier on in the thread.
rockthreegozy - Member
Saint axle is no use unless you use a Saint rear mech.
Axle
Bolts
This is the set up I used on my heckler (135mm spacing)with proII hubs:
This conversion kit:
10mm bolt through
This bolt:
hope 10mm saint boltand a track nut from my local halfords to tighten it all up.
Using the 10mm bolt through option means you could use the RWS Thru bolt but at nearly £40 it struck me as a bit overpriced....
OK thanks I get it now. Stu that looks like the best value option you've got there. A good upgrade for the Mojo I think...
surely the flex is in your spokes, what tension have you set them to?
Ed.
Now i've shown you something easy to understand perhaps you could show me how to ride a complex problem like the steps of death.
Topic Closed
