Viewing 3 posts - 1 through 3 (of 3 total)
  • Hope pistons and bleeding
  • pedlad
    So I’ve done a bleed before but have two questions:
    Pushing back the pistons (to get superstar pads in which I know may need a quick sand) they “return” back out a bit even though the system is open both at reservoir and bleed nipple ….why?
    When you do a bleed with the bite point adjust wound out I never really get the quick bite I want even with bpa wound back in. I’ve done the tilt tap and top up, but still not great.
    Do I need more fluid in system to achieve this?
    coatesy
    Sounds like your pistons may be sticking, probably worth stripping the caliper to clean them (and the seals and their grooves)and re-assemble with silicone lube.
    alanf
    I would imagine its the seals settling after you’ve returned the pistons. As Coatesy says maybe need to pop the pistons and seals and give them a good clean out. It’s suprising how much gunk sits in the recess for the seals.
The topic ‘Hope pistons and bleeding’ is closed to new replies.
