Viewing 6 posts - 1 through 6 (of 6 total)
  • Hope Picknmix headset problem
  • hamishthecat
    Just bought a s/h frame with headset fitted and I can’t get the top cover to sit flush on the bearing because the taper ring sits about 2.5mm proud. Either the taper ring is the wrong one or the bearing has the incorrect bevel – it seems to be in the correct way up.
    Anyone have any idea of the problem based on the pics?
    [img]http://i809.photobucket.com/albums/zz12/hthecat/P1070182_zpsotkxo2nw.jpg[/img][img]http://i809.photobucket.com/albums/zz12/hthecat/P1070172_zpslljvtnu4.jpg[/img]
    bobbyspangles
    looks wrong that does
    stenhousemuir
    Don’t think it is right
    bobbyspangles
    the conical washer looks too big for a hope
    nicolaisam
    As above thats not the correct Conical washer. Hope ones usually have a Parallel section then the taper.
    Either that one hasnt been machined correctly or its not for that headset
    hamishthecat
    Thanks Sam – I’ll check that out further.
The topic ‘Hope Picknmix headset problem’ is closed to new replies.
