Viewing 15 posts - 1 through 15 (of 15 total)
  • Hope Narrow/Wide ring
  • honourablegeorge
    Anyone using it? All good?
    jim25
    Are they even out yet?
    shortcut
    They are out – got one in the garage waiting to go on a bike.
    trout
    Forgive my ignorance but what is a narrow wide ring and what is it good for 😳
    reggiegasket
    the teeth are narrow, fat, narrow, fat, narrow, fat
    to match your chain which has wide, thin, wide, thin, wide gaps
    the upshot is the chain stays on the ring whatever you do. So chain guides are not needed.
    But you have to run just one ring (1×9, 1×10), with an even number of teeth (32, 34…)
    bikeneil
    My lbs has them in stock.
    trout
    Thanks Reggie
    matther01
    How much are the Hope ones?
    empireofthefun
    Thinking of going back to a single ring set up as since I went 2×10 I think I’ve only gone into the larger ring a couple of times. Do you need to fit a different cassette with the narrow/wide setup ?
    Nobeerinthefridge
    no.
    empireofthefun
    Good to know, standard chain then ?
    crankrider
    Pinkbike review of the Works Components one: http://www.pinkbike.com/news/Pinkbike-Product-Picks6.html
    Hope are only 8 months and a tenner late to the party….
    riddoch
    Aren’t those the standard chainrings in the picture? I was expecting more of a difference between the teeth.
    bikeneil
    Nope. They’re definitely Retainer rings. They are in the same packaging though. I’d have one if I hadn’t just bought a raceface one.
    Mugboo
    Are the rear 40t ones out too?
The topic ‘Hope Narrow/Wide ring’ is closed to new replies.
