Viewing 9 posts - 1 through 9 (of 9 total)
  • Hope Mono Minis question
  • DezB
    Mate has a front Mono Mini (circa 2007) IS mount – outer edge of disc fouls the caliper. I’m thinking the disc isn’t a Hope and therefore the wrong size.
    What size discs should they be?
    thanks.
    juan
    what caliper number?
    IIRC it’s 160/180/2000 and you may have a 203 as well.
    As usual I’m trying to answer remote questions without access to the bits, so don’t know.
    It looks like a 180/185 from the pic, so maybe should have a 180.
    juan
    well if it’s the mono mini (black) it’s 180. If it’s the mini it’s 185 they use a wavy disk. It’s doable to use a 185mm wavy into a 180 mono caliper, it take a little bit of grinding not much just a little bit due to the difference in the depth of the caliper;
    Definitely Mono Mini.
    Grind the disc or the caliper? 🙂
    juan
    caliper is easiest disk is safest
    Went for the disk 😉
    Yep, thats what I thought you’d say…
    How’s things in France anyway?
    juan
    France sucks, not tiem for biking no time for climbing I just miss good old UK to be honest. Weather is crap yes, food is a bit of a struggle yes, but people are way less prone to judge and much nicer…
    Sounds like you’re working too hard… see you at the BBB?
The topic ‘Hope Mono Minis question’ is closed to new replies.
